throttle discovery
Well made the trip across Texas without much issue on my 09sf (besides my ass feeling like it got hit with a 2x4). Ran into a problem with my throttle about 50 miles before I got home, snapped the throttle cable randomly. Jerry rigged the other throttle cable into place which gave me up to 6k rpm's, roughly 60mph which is too slow for the highways out here so I decided to just reach down to the carb and operate it by hand.
Before the cable broke I could not get the bike over 82mph on flat road. Working the carb by hand I was able to go above that without issue, hell could take the bike up to redline in 6th gear with ease. Does the stock throttle cable on the 09 and up bikes not allow for full movement of the carb? |
hmmm..... interesting.
Yes that is interesting.
Yamaha puts in a Longer set screw on the Off Road versions of the WR models to limit full throttle for emission purposes. You have to either cut the screw or buy an YZ screw. I wonder if there is a block or set screw in the hand throttle itself? |
So that is where the Mikuni carb gets the extra boost, it goes to 11!
You were crouched on your bike, wasn't you? Maybe you was just offering less air resistance than you do when sitting strait up???
i actually carry a complete cable replacement for throttle and clutch for long rides...certain parts like clutch and throttle cable assembly, spark plug, all bulbs, few bolts and nuts, zip ties, etc. i keep spares at all times...usually pick up complete clutch and throttle cable assembly on ebay from total loss klx250s/sf for super cheap...like $10 each...
Originally Posted by DustyCowboy
(Post 484468)
That is what I thought about also. But it would be nice to know if there is a restriction in the throttle movement. |
Okay, who's taking their carb off next to check this out?
Originally Posted by IDRIDR
(Post 484471)
Originally Posted by TNC
(Post 484479)
Mine's off right now setting on the workbench after installing the TM36. What exactly do you want to know? Not sure what inspecting the carb will do in light of what the OP is describing. I'm kind of thinking the OP may have had too much slack in the pull cable.
