For those who say they can wheelie in 2nd
Is this done with some body english, or is it done with just hitting the gas and the bike comes up on it’s own? If it comes up on it’s own, what are your mods, weight, and gearing?
I can get mine up in second on flat ground with some body english, but not with just hitting the gas. I weigh about 190 lbs. and my mods are Full Muzzy 128 main N1TC needle on 2nd clip from top 2.25 turns out on screw Drilled airbox Airbox lid removed Smog removed Stock gearing 190lbs |
RE: For those who say they can wheelie in 2nd
Clutch. |
i just yank up on the bars... and i can get mine up in second...
I think the gearing change is important in getting the wheel up in second with out any effort. Try a 13t in front and 45 in back.
major component of 2nd gear wheelies is a BigGun EvoX full system. LOL Ok, just kidding. Like someone just said, the 13-tooth front sprocket helps immensely. The way I usually do it is shifting hard from 1st to 2nd and sometimes I can ride it out and get into 3rd. But no it won't just come up on it's own. That takes power this little burger just doesn't make. But once you do get it up it actually is pretty stable and you gotta watch it or you'll go over backwards. I can get a 1st gear wheelie with just throttle and rpms but what fun is a 1st gear wheelie? I weigh 150 lbs, 5'7 so I'm sure that helps me out as my bike doesn't pull much weight around.
i just blip the clutch in 2nd, once you get it down, shift to 3rd and 4th and ride it out!!
I can whelly if I hit a bump just right and give it gas
[sm=ttiwwp.gif]
Lets see some of these wheelies. |
1 Attachment(s)
when i get mine back together from all the enduro damage i'll try to post a vid. here's a small pic
Attachment 33613 |
Viagra!
