Thinking of selling my 2006 with 351 Kit & Mods
Old Oct 12, 2024 | 08:39 PM
Slyder211's Avatar
Default Thinking of selling my 2006 with 351 Kit & Mods
Thinking of selling my 2006 with 351 Kit & Mods. Here is what I have done to the bike.2006 KLX250S Original Plastic Garage Kept, When people see it they think it is new!
5100 miles
BB351 Kit @ 3500 miles along with
Marcelino Cam Mod
TM36-68 Pumper Carb Jetted V-36, Main-127.5, P12.5, Needle P-8 3rd clip, Needle Jet 9DZH6-50, Air 10, 1¾ turns out.
Two Brothers Exhaust & Stock Exhaust
K&N Air Filter Snorkel Screen and top Mod
Race Tech Gold Valves front suspension with Cogent .46 kg/mm springs
Rear shock Cogent 7.0 kg/mm spring
Pivot Works Fork Kit
Pivot Works Swingarm Kit
Gaffer stainless brake lines front and back with new fluid & Neutron Sintered pads
ProTaper Bars with ProTaper Sport MX Half Waffle Grips
Tusk D-Flex Handguards with MX Shields Green
Mefo Explorer Dual Sport 90/90/21 Front Tire
Mefo Explorer Dual Sport 120/90-18 Rear Tire
520 XRing Chain @ 4000 miles
13, 14, 15 and 16 Front Sprocket 47 Rear Sprocket @ 4000 miles
Lithium Battery
New Clutch Plates & KTM Clutch Spring Mod @ 4000 miles
Does $2400. sound like a reasonable offer? It is a little dirty in the pictures I went riding in the Ocala forest a couple of weeks ago and have not had time to clean it up.
Old Oct 12, 2024 | 09:14 PM
GBAUTO's Avatar
I'd ask for more.
You have made a machine that is comparable to many higher end bikes.
Old Oct 12, 2024 | 10:24 PM
RaceGass's Avatar
I concur with the above poster.
Or remove the easily installed modifications and resell them, recoup some of the money you’ve spent. You’ll probably have no problem selling your bike. I resold my ims 3.0 tank & Utah skidplate, Oem plastics quickly, there’s a lot of klx owners looking for mods.
Can you elaborate on the Ktm clutch spring mod?
Old Oct 12, 2024 | 11:34 PM
Slyder211's Avatar
The clutch on the KLX250S works fine when stock, but when you do major mods and almost double the power it can not take it without slipping and after one day in the woods it is toast. The solution is to order Barnett clutch springs # 501-40-06017 I will include pictures KTM spring on left, original spring on right ( hey now say for KTM 690 - 990 originally for KTM 450) . You only use three of the springs and leave in 3 of the original springs. The clutch pull is slightly harder but not like a 70's motox bike. If your clutch is slipping do yourself a favor and change the clutch plates and this spring setup and you will never have another problem along with no more overheating in tuff conditions which is normally caused by a slipping or abusing the clutch more than going slow in tough trails. remember we have a radiator fan! Adding an adjustable fan interface like the one on my handlebar brace is really nice. If you change your clutch plates make sure you soak them in whatever oil you use in your bike for a minimum of 24 hours (longer is better) this is one of the single most missed tricks that people do not do and wonder why there new clutch only lasted a few rides. Factory teams soak them for a week minimum.
Old Oct 13, 2024 | 03:48 PM
1994klr250's Avatar
I'd also agree that you are low on that price. That's a well setup klx. I always liked the looks of the 06-07 klx better than the 09+. The mods that you have done to it make it a much better bike than what it was stock.
Old Oct 13, 2024 | 04:30 PM
Tacoma660's Avatar
I’d ask 5000 around there
Old Oct 13, 2024 | 05:08 PM
Slyder211's Avatar
Well it sounds like $2400. is a great deal. I will post it on Facebook Marketplace in a few days. This will give Forum members a few days with the inside track for friends. I live in Ocala, FL.
RGLee
Apr 16, 2021 12:24 PM
Slyder211
Mar 30, 2021 03:32 PM
Illking
Oct 27, 2014 04:01 PM
cjc
Jun 15, 2011 08:18 PM
