Airbox Mod Question
Airbox Mod Question
Hello! I have an 09 KLX250s and was just wondering if removing the snorkel or the air box cover will require me to change anything on my carb. I would prefer not to have to mess with the carb in all honesty. Thanks!
No worries brother, there are plenty of folks here that can help with the carb.... it is easier than it looks and tons on pictures and info available.
Key tip if you take it off to do any sort of work or jetting is to put the diaphragm in a cup of hot water to keep it soft and proper shape to fit back in place. I think that's one of the tips from Pippin, not sure about Dyno Jet. I did it just to make sure it went back in nice. It did.
Carbs on bikes like are mostly simple compared to automobiles. Just make sure you know the order of parts, like the slide area. Jets and such are obvious. There are only a couple and they cannot be confused when refitting. The pain in the butt about carbs is if you have to remove them a couple times when jetting. That is the difficult part.
KawasakiKid, You probably already know this, but let's get it said - A "wrench session" to remove your carb and install a DJ kit, must be done 100% correctly and successfully or you will redo the session as many times as it takes to get it done 100% correctly and successfully.
If you are the type that can accomplish 99% of it only to FUBAR the last 1% ( like re-connecting / re-routing hoses incorrectly) , you'd better set aside an entire weekend.. Reverse those %'s and you'd better set aside a month..
In this, I can guarantee you that what seems like childsplay to some of us is practically impossible for others - I / we have seen this in here time and time again.. Hell, getting the rear boot back on correctly is sometimes overlooked by even us "He-Men socket garglers"..
See my link below (CVK34 list of...) to see some of the issues that can crop up..
