T fittings for carb vent mod?
Old 05-09-2007, 02:34 PM
Default RE: T fittings for carb vent mod?
depending on which side you accidentally lay the bike down on, thats the side gas dumps out on....
Old 05-09-2007, 02:52 PM
Silver_Otter's Avatar
_____________________________
"Official Mudslingin' Pole Dancer of PWI"
Eric - Pittsburgh, PA
2000 GMC Sierra
2006 KLX250S [align=right]
[/align][align=right][/align][align=left]
[align=left]So ? [/align][align=left][/align][align=left]These are air vents when you pick up the bike upthat correct it self. Just as it did before the mod.[/align][/align][/align]
________
How To Roll A Blunt
Old 05-09-2007, 08:03 PM
ol guy's Avatar
Location: Kennewick Washington, in the washington desert
ORIGINAL: Silver_Otter
2000 GMC Sierra
I think the whole idea of the mod came about because when you road through deep water the vents sucked water up in to the carb and the bike stalled. Even with one up and one down they both have vacuum and water would still be sucked up. With the mod it won't suck water yet it will vent if tipped over.
Old 05-09-2007, 09:02 PM
Kawi Wawi's Avatar
OK, whoever has the stock vent lines, can someone repeat the cup of water experiment one vent line at a time?
If either tube can be submerged (one at a time) and the bike still runs, then I'd say Silver Otter has a good point.
Old 05-09-2007, 10:21 PM
JB1's Avatar
JB1
JB1 is offline
I still dont see what the big deal is. I modified mine and it cost a whole $1.50
Old 05-09-2007, 11:05 PM
ol guy's Avatar
ORIGINAL: Kawi Wawi
I did back before I did the mod. One at a time. one had more vacuum than the other but they both pulled water up.
Old 05-10-2007, 02:58 PM
quote:
ORIGINAL: Kawi Wawi
Did it draw the water all the way into the carb or just up some?
Did the engine stop running?
________
Children Paxil
Old 05-10-2007, 06:14 PM
ol guy's Avatar
quote:
ORIGINAL: Kawi Wawi
The thing to do is give it a try your way and see what happens. Be sure to post the results. You may save some work for the guys coming along.
Old 05-10-2007, 06:42 PM
JB1's Avatar
JB1
JB1 is offline
did you rev up the rpms while it was in the glass or just at idle?
Old 05-15-2007, 02:28 PM
[blockquote]quote:
[blockquote]quote:
quote:
ORIGINAL: Kawi Wawi
[/blockquote]
[blockquote]quote:
[/blockquote]Did it draw the water all the way into the carb or just up some?
[/blockquote]
I don't understand why you guys are doing this vent line mods.
[/align]
[/align]These two vent linescome from the same carb float area on opposite sidesof the carb.
[/align]Why not just run one up and one down?
I run one vent linesup and one down.
I put the downvent lines in a glass of water.
I startedand revvedup the motor and it run normally.
I believe this is a good solution to high water.
And less stuff under the gas tank, which I like a lot.
[/align]
________
Children Nexium
Quick Reply: T fittings for carb vent mod?
