Supermoto wheels - what do I need?
Hey Guys,
I just picked up some stock KLX250SF wheels on Ebay and it comes with just the rims/tubes/tires. I currently have an 09 KLX250S and plan to remove the stock rear sprocket and rotor and mount them on the new SF wheels. Will they mount up fine or would I need a new front brake kit? Thanks! |
Hi
I fitted a set to my 09 klx a few months back used original discs and sprox just be careful removing disc bolts( there is threadlock on them and Allen head can easily get damaged. The only thing I had to do was fit a speedo healer as 17" front rim made the speedo reading way out. Regards Alan |
I did the same thing.
The sf does have a larger brake disk in the front, but you can fit the s model disk. There is a brake spacer bracket and a larger disk that came with my wheels. If you don't have the SF disk, or spacer, it will still fit. |
| All times are GMT. The time now is 02:14 PM. |
