Stock KLX300 performance mods - The best combo is FREE !
Old Jun 14, 2025 | 12:23 PM
tsc's Avatar
tsc
Originally Posted by Klxster
I assume the pedestrian perspective is "bigger injector = more fuel".
It is almost as simple as that. The caveat is that different injectors have different open/close latency. It seems it is not so different between OEM 220 and chinese suzuki gsxr 270.
What I can say - many people are successful with just 270cc injector and JDM ECU on klx300 (without fuel controller!). Few need fueling refinement. Obviously everyone has slightly different set up, but I still didn't figure out why is that.
Old Jun 14, 2025 | 07:39 PM
Klxster's Avatar
It's all subjective opinions, non data driven, non verified, dyno butt crap.
Has anyone ever checked the result of installing a 270 injector via back-to-back dyno runs ?
Dyno-Butts and subjective opinions regarding results have no merit - my dyno testing proved the engine will run "perfectly fine" with horrible fueling -f ueling that ranged as lean as in the 14's and as rich as in the 10's. h
Hell, my bike never felt "more alive" than when I was feeding it horribly rich fueling - WOT in the 10's :1. So much so that even after a dyno run showed the truth, I still ran that fueling for a while.
That is when I learned that my Dyno-Butt was just as flawed as everyone else's..
Old Jun 14, 2025 | 11:20 PM
hart125's Avatar
That "stumble" you are describing has all the characteristics of a air leak somewhere in the induction tract.
Yeah, I really thought that but it was perfect as soon as i put on the 300 ecu. I was just about to get bung welded into my header cause I have a fast AF guage. A lot would have been answered if I had done that. I could have seen if the AF got non linear in closed loop,, transition to open loop, etc.... I'm basically landing where this thread has suggested 300 with no stp kdx snorkel and a little extra fuel in the middle. Seems to me with the stp removed there might need to be a little more fuel right where the dip shows up on dyno's.. Is this true? Thanks guys!
Old Jun 15, 2025 | 02:39 AM
Klxster's Avatar
IIRC, if the airbox and exhaust are left stock, removing the STP ( secondary throttle plate ) does not cause AFR to go so lean as to be of concern. I think I recall the area of most concern (midrange) makes it into the mid 13's. THis is not performance fueling but should not cause any harm as it is limited to midrange ops only - the ops that were muzzled with the STP.
Old May 31, 2026 | 06:45 PM
Bullfrog12's Avatar
Wink
You just need to get your "Dyno" recalibrated..."Butt" I agree with you .
Audible noise can be very deceiving as well...louder doesn't necessarily mean more powerful.
Klxster
Aug 13, 2024 02:18 AM
wmill27
Sep 24, 2021 06:03 PM
Michaelb2
May 7, 2015 02:08 PM
GreenKLX
KLX300R
Sep 6, 2007 08:28 AM
klxcrazy
KLX300R
Jun 25, 2006 10:25 AM
