Stock exhaust
Old Feb 28, 2025 | 09:44 PM
RaceGass's Avatar
Default Stock exhaust
Does a 06-7 klx250s stock Oem exhaust fit a 09-14 klx250s? Thanks
Old Mar 1, 2025 | 06:18 PM
1994klr250's Avatar
I'm fairly positive that the header pipe will fit, there might be differences in the mounting location for the muffler though. I know that Kawasaki did make changes to the aft part of the subframe from the 06-07 to the 09+ klx.
It shouldn't be difficult if there's differences in the mounting tabs. I put a 06-07 klx 250 exhaust on a klx engine that I swapped into a klr250 frame. I just made some 3/16 steel relocation tabs.
You can see that I used two out of the 3 muffler mounting tabs. I made them out of some simple 3/16 x 1 flat steel. Shouldn't be too difficult if you have to do something similar for the different year klx's.
Old Mar 2, 2025 | 06:26 AM
RaceGass's Avatar
Very quick thinking on your part to getting that bolted up. I was looking at Partzilla comparing the part numbers, the illustrations show those parts looking very similar in mounting points. Thanks for the pics, shows how easily it can be done 👍 Looking at the passenger peg mounts, those could be adapted to many other bikes if needed. I’ve never ridden a klr250. The conventional forks & drum brake take me back to the old Yamaha days dt-1 at-1 rt-1.
Graybo
Sep 6, 2013 08:45 PM
Johnny B.
2000 & 2000 Limited
Nov 5, 2012 02:11 PM
djb
May 29, 2011 10:49 PM
eveloso
Oct 22, 2009 11:38 AM
preemo_21
Ninja ZX-7R
Mar 7, 2008 11:12 PM
