Stock carbs 06 vs 09?
Old Oct 5, 2011 | 02:36 PM
revtor's Avatar
Default Stock carbs 06 vs 09?
Hey guys, are the stock carbs the same from the 06/07's to the '09s?
thanks
~Steve
Old Oct 6, 2011 | 02:43 PM
WestOzKLX's Avatar
As far as I know they are. Why do you ask??
Old Oct 6, 2011 | 07:20 PM
linkin5's Avatar
I don't know if they are identical but you should be able to use one in place of the other with little to no modification.
Old Oct 6, 2011 | 07:56 PM
revtor's Avatar
I was looking to get one for the time being as I swap from FCR to TM34..
Old Oct 7, 2011 | 07:28 PM
roadglider's Avatar
I'm not sure but I have a vague recollection that the pre 09 carbs had a TPS and 09 and later didn't. So if your trying to put an 09 carb on an earlier models you might run into problems. Vice versa should be OK though as you could leave it unplugged. You might post this up on TT and see if Brewster responds he knows alot about these bikes.
BlackNinjaZX6R
Jul 23, 2007 08:42 PM
markmeinteil
Classic Sportbikes
Oct 17, 2006 05:59 PM
goedertd
750
Jun 9, 2006 09:56 PM
goedertd
750
Jun 9, 2006 09:18 PM
beaupower32
Aug 4, 2005 10:40 PM
