Stator layers need to be insulated? Dents in stator.
Old Feb 3, 2013 | 09:22 PM
Default Stator layers need to be insulated? Dents in stator.
OK so some of the chewed up gear teeth from my stater fail( https://www.kawasakiforums.com/forum...e-cases-39378/ )must have been caught between the stator and the flywheel and impacted the stator, denting it. I don't know anything about how these things work, so I'm asking you guys.
A couple of the "dents" look like they have tied together at least a few of the layers of the stator. My question is do these layers need to be insulated from each other? I plan on cleaning up these dents but would like to know how critical it is to keep the plates separated.
Thanks Dan.
Old Feb 3, 2013 | 09:45 PM
Dark Angel's Avatar
Strictly speaking, yes. The laminations need to be insulated from each other to prevent eddy currents and excess heat production. Now back in the real world a couple of little dings here and there shouldn't make a HUGE difference and may not make a noticeable difference at all. It's not ideal, but it may not really matter that much either.
Old Feb 3, 2013 | 09:54 PM
Ha ha , so cool I get a quick answer from opposite side of the world!!
Thanks DarkAngel I'm assuming that the outside diameter of the stator is somewhat critical. Probably not a good idea to file down through the dents to get to a point where the plates are still separated?
Dan
Old Feb 3, 2013 | 10:00 PM
go cytocis's Avatar
I believe the insulation is essential. My Honda 919's charging system quit generating electricity when a little cast aluminum nub in the engine case which was making contact with the stator eventually wore through the insulation after 40,000 otherwise trouble-free kilometers.
Old Feb 3, 2013 | 10:11 PM
Dark Angel's Avatar
Dan
Yes but only in as much as it won't mount properly if you take too much material off. If you can do it carefully just where the damage is and then put a little varnish over the area (proper electrical varnish is preferable) you should get away with it. Be VERY careful to remove any and all metal dust/particles you make though.
Generally, it is. If the laminations aren't insulated from each other the eddy currents can saturate the iron core and prevent the alternator from doing anything meaningful. If that happens the iron will heat up significantly and burn through the insulation on the windings and ruin them. In your case, assuming there was no other damage, you should have been able to clean the area up and replace the insulating varnish. You can get it in spray cans or if you find a motor rewinder you should be able to get them to re-varnish the whole thing and get it baked properly as well.
Old Feb 3, 2013 | 10:17 PM
Lotrat's Avatar
The laminations are insulated from each other to prevent losses, but it will still work. Clean it up just enoght to seperate the laminatons. I'd be more concerned you have a short in the windings. Look for cracks in the magnet wire insulation coating. An internal ding like that will short it out.
Old Feb 3, 2013 | 11:58 PM
go cytocis's Avatar
Originally Posted by Dark Angel
In your case, assuming there was no other damage, you should have been able to clean the area up and replace the insulating varnish. *You can get it in spray cans or if you find a motor rewinder you should be able to get them to re-varnish the whole thing and get it baked properly as well.
Thanks for the tip DA!
In my case unfortunately I was 1500km (~1000mi) from home and at the mercy of the repair shop which just ordered a new stator from Honda and installed it after grinding the nub down.
Old Feb 4, 2013 | 12:57 AM
Thanks for all the replies. I cleaned up the grooves between the plates as well as I could. I wasn't having any electrical problems, that I knew of, before the starter gears let go, so I'm going to pop it back in and see what I get. I do see some cracks on the outside of the thick insulation layer,but not necessarily any on just the wire insulation itself.
Dan
Old Feb 4, 2013 | 01:19 AM
Lotrat's Avatar
I'd run it as is. Yours has a thick varnish on it. Here's what a new high output unit looks like:
Old Feb 4, 2013 | 01:24 AM
mmmmm looks nice. Is that for the KLX? What does someting like that cost?
Dan
