Sproket
Old Sep 16, 2014 | 12:02 AM
oside5ka's Avatar
Default Sproket
What would a 1 tooth in front do over stock
Old Sep 16, 2014 | 12:05 AM
what are you trying to accomplish?
gearingcommander.com
Old Sep 16, 2014 | 12:39 AM
oside5ka's Avatar
just wanted to know what it will do to pick up top end speed, got one for 5 bucks from a buddy just wanted to know that it did before i did it
Old Sep 16, 2014 | 03:56 AM
wildcard's Avatar
I will increase you final drive ratio (make the gears "taller). If you still have a 250 it might make the bike seem to be down on power but will make highway driving a little easier.
Old Sep 16, 2014 | 05:00 AM
NorCalKLX's Avatar
Let me know how it works, I was thinking of trying a 15T for highway rides.
Do you need to add a link for that or does the stock chain offer enough adjustment?
Old Sep 17, 2014 | 09:33 AM
grahamgower's Avatar
I use a 15 tooth on my 331cc on road sometimes (SM Kit ). Nice tall gearing. Not so cool off road when I use trail set up. Too tall in first and second for gnarly climbs.
However having said all that, on a standard 250 you may battle a bit pulling at top speed in 6 gear. I doubt if you will rev out, except down hill. ( You may find you are faster in 5th. 6th becomes a cruising overdrive) It will make the whole on road experience more pleasant and a lot less 'buzzy'.
Old Sep 17, 2014 | 10:42 AM
turbomaniac's Avatar
more tooths to the sprocket near engine (front sprocket) means longer gear ratios.
more tooths to the rear sprocket (near the wheel) means shorter gear ratios.
i wouldnt recomend a 15 front tooth for a klx 250.. It would be way longer than it sould be and very bad for dirt riding... the stock 14 sprocket is ok for tarmac use and less dirt use, imagine what will happen if you use 15.
Old Sep 17, 2014 | 03:45 PM
RockabillSlapMatt's Avatar
Youll get 75+mpg with the 15 tooth front at 45mph
Old Sep 17, 2014 | 04:07 PM
Angier's Avatar
It would make a marginally-slow bike even slower, clutch slip more to get moving and reduce the rpm a bit at higher cruise speeds. It wouldn't necessarily improve mileage *noticeably* at higher cruise speeds, given that the throttle may have to be held more open.
All said, it's a cheap thing to try out to see if it suits you....and I see you're in Nevada so the mileage may get a tad better if you keep the speed down
Old Sep 17, 2014 | 04:28 PM
Ill disagree because when I had the 250 a 15 tooth frot gave me a large improvement in mpg.
