Sprocket & Chain Life on a KLX 300S
Hello Forum,
If I use my KLX 300 mostly mostly on the street, and a little bit here and there for some light back roads and trails. Also, 6 months of the year it’s in storage for winter. About how many years should I expect getting out of my sprockets and my chain? Thanks. |
At least 15,000 miles. That's what I'd get on the O-ring chain on my KLX650 - with really lousy maintenance. Just don't overtighten the chain, it is better to run a shade loose than even a bit too tight. The KLX chain would have run longer but a lot of my riding was dirt/gravel road riding, lots of dirt on the chain and sprockets.
Your going to need a battery tendor or charge it at least once a month.
Huh? What’s a battery have to do with chain or sprocket?
Originally Posted by klx678
(Post 554104)
Pretty sure they do come with an O-ring chain. Look at the links, you should see the O-ring between the outer plate and inner plate of the links.
Only way it wouldn't have one is if someone replaced. Only racers and tight wads run non-O-ring chains. Racers, because there is less drag which means less power loss - but then again they take off the chains to clean and lube them after every race day or more often. Tight wads, because non-O-ring chain is far lower cost, problem is they need extremely frequent lubing and cleaning or they trash out fast. |
U sound like a newbie, worrying how long a chain is going to last on your new bike. If you don't put a charger on your battery, that is going to be your first issue. Long before the chain is even dirty it sounds like, since it's in storage for months.
Originally Posted by durielk
(Post 554113)
See, well now you have a battery. And you'll be getting a battery tender soon.
I may or may not be a tight wad but I run a non O-ring chain on my KLX. O ring chains do have more drag. The 250 isn't exactly in great excess of power. And I prefer the ponies go to the ground rather than turn a chain with slightly moee drag. Also, fuel range would be slightly longer with a non O-ring chain. Yes it requires more maintenance and yes it'll wear out faster than an O-ring chain. I'm not saying I'm right and they're wrong. Nor vice versa. Strictly personal preference.
| All times are GMT. The time now is 11:19 AM. |
