Spark Plug Upgrade
What is the best spark plug upgrade for a 2009
Rik |
I doubt the plug is your problem but you could go one hotter. If you have an 8 in there go to a 9.
waste- just clean your current plug with a wheel and regap. there are no benefits to a hotter or iridium plug in this engine other than a placebo effect.
In NGK a 7 is hotter than an 8 I just talked with NGK technical support and sent them a photo of the plug tip - it is wet fouled which they say is common with a jet kit and needs a hotter plug to keep it clean. If the tip is black at all it requires too much voltage to start.
Originally Posted by Sail-A-Wai
(Post 354310)
(Post 354310)
sounds like he got expert advice form the spark plug pros to me.:rolleyes:
Originally Posted by hoedogg
(Post 354475)
IG is dead set against anything he hasn't tried yet. Anybody who's done some performance mods and rides aggressively would be better-off going with 7 (next step hotter) plug. |
