spacers for JT CS sprocket??
Well, I went to my local dealer too get an AFAM 13 tooth CS sprocket, and they didn't carry them. They only carry JT because AFAM's are too expensive! I got the JT knowing that there was something about them that I didn't like; I get home and look on here..NOW I remember..those danged spacers! The question is; has anyone came up with a difinitive answer for the spacers? I've read that you PROBABLY need 3x.035's?? Does anyone know for sure? Apparently my dealer doesn't know anything about it, or they would have hooked me up when I bought the sprocket.[:'(]
RE: spacers for JT CS sprocket??
Dave, which JT did you get? JTF516.13 is the exact fit, no shims. Scat added the 3 (.035) shims for the Renthal I believe.
Hey Tony. The part # is JTF569.13. It actually showed in the parts book as being for the KLX250s. The sprocket is flat on the sides though. I was under the impression that there should be some sort of "lip" on the side.??
ORIGINAL: konacoiler Hey Tony. The part # is JTF569.13. It actually showed in the parts book as being for the KLX250s. The sprocket is flat on the sides though. I was under the impression that there should be some sort of "lip" on the side.?? Dave the JTF516 has the same shoulder as the stock. http://www.jtsprockets.com/fileadmin...all/jtf516.jpg |
Thanks Tony. I was looking at that on the JT website. I'll take it back and exchange it for the 516. Thanks again for the help.
