some issues after carb mod?
So this is my setup at the moment.
125 jet 38 jet snorkel removed half inch hole in first baffle of stock pipe air screw 2.5 turns out second needle clip 13t sprocket When I am driving at a constant high speed it will hesitate for a second almost like it skipped a tooth on the sprocket(just best way to describe the feeling) also will do it once and awhile on quick takeoff but more during steady road driving. Would this be a air screw adjustment needed or go bigger than the 125 jet? I put the needle to the third clip and the bike just bogged out and wouldn't start.?? Also I am pretty much at sea level for elevation |
| All times are GMT. The time now is 10:27 AM. |
