-   -   SOCKET SIZE (https://www.kawasakiforums.com/forum/klx-250s-71/socket-size-2595/)
raider Mar 2, 2006 12:23 AM
SOCKET SIZE
What size socket do you need to remove the CS sprocket.
sdunne Mar 2, 2006 01:03 AM
RE: SOCKET SIZE
27mm same as right axle nut.
bmwhd Mar 2, 2006 01:38 AM
RE: SOCKET SIZE
ORIGINAL: sdunne
Bingo!
1 1/16" (or maybe 1 1/8", I forget) will work in a pinch but be careful not to round corners.
Any auto parts store will have a 27 mm impact socket in the brake / axle repair section of their tool crib.
idmonte Mar 2, 2006 04:44 AM
RE: SOCKET SIZE
<---- hugs his snap on tools
motoguy128 Mar 2, 2006 05:17 AM
RE: SOCKET SIZE
I wihs I had an impact gun... I'm still trying to figure out how to loosen off the countersprocket bolt. My last biek weighed 150lbs more so it wasn;t a problem. It just spinds the tires and the engine. I think i'll need something to hold the rear brake while I loosen it.
MaverickAus Mar 2, 2006 07:53 AM
RE: SOCKET SIZE
get an impact wrench they dont cost much and you will use it a lot on bikes. BTW Kawasaki do NOT include a 27mm spanner in the toolkit [:@] I found out when I got a flat
Gravy Train Mar 2, 2006 03:29 PM
RE: SOCKET SIZE
My front sprocket bolt came right off. I didn't need a impact gun. All I used was a breaker bar and one of my buddies foot on the rear brake. Just make sure that you tap the washer out of the way, since its bent over the bolt. That might be your problem.
Just on a side note.... I saw a very increase in bottom end when I changed the front sprocket..... Wheeles in second gear.. No problem at all...
Good luck!!
MaverickAus Mar 3, 2006 11:17 AM
RE: SOCKET SIZE
There will come a time when you "need" it, worth every cent.
st.marys Jul 11, 2006 11:49 PM
RE: SOCKET SIZE
this is exactly the info i was looking for. i have a new KLX250S and i did a recent ride in the Allegheny National Forest of Pennsylvania with my brother. he has a CRF230 and crawled over rocks and the slow stuff with ease. i had to play the clutch alot when creeping up hills and at times had to go too fast at times to get the power i needed. it sounds like all i need to do is change the front sprocket only...not the back. is this true?
deej Jul 12, 2006 01:13 AM
RE: SOCKET SIZE
Stock gears 14-42 OK for fire roads and highway, and 6th gear is worthless. 13-45 gears, Muzzy exhaust and jetting that's what I'm talking about baby!!!!!!!!!!!!! Wheelies in 2nd and lots of low end torque. Even 6th gear has great acceleration now, so with the 13-42 and before the mods, I was at 6000 rpm's at 60 in 6th gear, now with the 13-45 and the other mods I'm at 6800 rpm's at 60 in 6th gear.
