09 KLX250S.
Trying to determine where a couple of small leaks are coming from. First one seems to be coming from some kind of an electrical connection tucked in behind the shift lever.
The other appears to be coming from behind the shift lever
Is there a typical cause that I should be looking into? Gasket?
May be attributed to chain lube (normal) or counter sprocket seal, which is usually caused from having the chain adjusted too tight. Clean the area real good and keep an eye on it. BTW-the chain appears to be well lubricated.
Are you noticing and drip spots where you park the bike?
