Replacing clutch perch and control switch
I realize thereīs a pin under the clutch perch thatīs supposed to check clutch position to start the bike, I believe...right?
I want to replace the perch and I am wondering what I have to do with that wire and how to close the circuit.
Another question is if any of you replaced the control switches - lights/horn and start/kill - with smaller (narrower) ones.
I want to replace the perch and I am wondering what I have to do with that wire and how to close the circuit.Another question is if any of you replaced the control switches - lights/horn and start/kill - with smaller (narrower) ones.
I guess the best way to learn is to fiddle with it. Found out that if the wire for the starter lockout switch is disconnected, the bike wonīt start unless itīs in neutral. I can live with that.
Originally Posted by ahnh666
i guess since i broke the pin..the bike can now start and jump if i start it without the clutch when not in neutral....right?...
I have my eyes on this clutch perch:
http://www.righteousstuntmetal.com/
I bypassed that clutch switch, either by opening or closing the circuit, don't remember. So yes, my bike will start, or at least try to, in any gear with the clutch in or out. For my locations of riding, this is safer. Kill on a steep hill, can't get feet off the ground safely to get to neutral, pull the clutch and start her up.
was thinking..if i broke off the pin, the moto always thinks i have the clutch lever in...wouldn't that mean the starter will always work in any gear regardless of clutch?...will have to test later...
just tested it...my guess was correct...the starter works no matter if i'm in gear or neutral with the pin broken off...becasue without the pin, it always thinks the clutch is pulled in...
