Replacement countershaft washer
Old Jun 6, 2012 | 09:09 PM
jhoffy22's Avatar
Default Replacement countershaft washer
My washer doesn't have a tab to bend over the nut, anyone elses like this?
Old Jun 6, 2012 | 09:19 PM
ahnh666's Avatar
are they suppose to have a tab?....i bought a replacement and it was just flat...i just used a flat screwdriver and a hammer to make the bend...after two or three times of flattening and bending, i needed a new washer...
Old Jun 7, 2012 | 02:42 AM
jhoffy22's Avatar
This is exactly how mine came, and yes I think they are supposed to have a tab. What I ended up doing was using a flat screwdriver and hammer to pound part of the washer down against the nut.
Pretty scary, but I followed the torque specs for the counter shaft bolt the last time I removed it and it was lose against the case saver when I took it off today. I put some oil on the inside of the sprocket where the countershaft goes into the engine and put some loctite on the countershaft to help keep things secure. We'll see how it goes this time. I really hope I don't have to replace the washer every time I want to swap sprockets.
I switched to a 15t up front so I'm 15/42 now with my 351 and I love it!
Old Jun 7, 2012 | 03:23 AM
RayCour's Avatar
The OEM washer does not have a tab, at least it don't on my bike. Nor does the illustrated parts breakdown shows one. You simply bend it like you did.
Old Jun 7, 2012 | 03:28 AM
jhoffy22's Avatar
Is yours shaped like a bowl? Mine was not flat either. I figure that instead of replacing it each time I can just bend a different side down to I don't wear the steel out by bending it back and forth.
Old Jun 8, 2012 | 01:32 AM
RayCour's Avatar
Yes, bowl shaped if I remember right. And yes, bending a different side each time is a good idea
Old Jun 8, 2012 | 07:05 PM
rgoers's Avatar
Bowl-shaped, no tab, bend it over... doesn't need to be smashed tight against the nut, just needs to provide enough resistence to prevent it from turning on its own.
regulatorifx
KLR250
Aug 8, 2012 04:47 AM
stephenmarklay
May 1, 2012 02:06 AM
Stashu
Nov 17, 2011 02:20 AM
greenmachine
Feb 9, 2010 02:24 AM
BR3668
Oct 22, 2009 02:25 AM
