Rejet for Elevation. Wow.
I knew I had my bike set up rich, but, I did that on purpose for the hot desert riding I did, which also included some riding below sea level in Death Valley. Since I moved to a spot just over 5000 ft, and plan to be riding trails even higher, I bumped the main down to 128 (from 132) and the Pilot down to stock 35 (from 40). The darn thing will lift the front wheel off the ground with throttle-only now. I wonder if I should try a 124 main? Anyone else with a 330 or 331 Big Bore run less than a 128 with good results? Thanks!
I am at 3300 ft. elev. and often ride up to 7-8000 feet and I have the same exact jetting as you do now.
It runs fine up to about 9000 ft. and then starts bogging a little bit. I ran a 124 with the stock bore and it was about perfect. I think with a big bore though, it might be a little lean. I know with my 128, I have no black soot and very little popping so it has to be close to the right jetting. |
Black, is that a DJ128?
I am jetting for CO, will be installing a 32.4 PJ with 130 MJ Mikuni as soon as the shop delivery. Snorkel, 351/Pumper34 carb, stock otherwise. Hoping this will run at 3300-10,000+ ft. |
Originally Posted by durielk
(Post 478199)
Originally Posted by BigSky KLX
(Post 478193)
Where you riding in N. Utah? I used to live in Ogden and then Eden/Huntsville up in the Ogden Valley. There's some awesome riding up high on Monte Cristo and of course all through the Wasatch.
Originally Posted by djchan
(Post 478205)
Ah, Morgan. I used t take the Trappers Loop south from Huntsville to Morgan and then into Hill AFB when I was stationed there a few years ago. Pretty country and IIRC isn't it home to Browning Arms?
(Post 478228)
Ah, Morgan.
IIRC isn't it home to Browning Arms? |
Ya, that's why I was willing to make the drive from Eden. No smog and no jet fuel. Lotsa snow up in the valley though. 3 ski areas within 20 minutes of my house. In those days you could get home from work and go night skiing at Nordic Valley from 4-11pm for $7. I'm sure those days are gone since the Olympics came to town.
