-   -   red grease on the air filter (https://www.kawasakiforums.com/forum/klx-250s-71/red-grease-air-filter-13597/)
sheena12 Jul 8, 2007 06:33 PM
what is the red grease on the bottom of the air filter i have 228 miles on the bike and its time to start the mods
incabiker Jul 8, 2007 07:36 PM
RE: red grease on the air filter
Thats the grease that needs to be on the air filter. You can go buy this grease at any cycle shop. You take and wash the air filter, let it dry out, then spray it with that tacky red grease, that helps it catch a ton more dirt and anything else trying to get inside your engine.
mmatz Jul 8, 2007 09:01 PM
Use a quality spray cleaner such asCleanup Degreaser from Maxima Racing Oils, then oil your filter with PJ1 or comparable and you are good to go. I try and put a little extra on the sealing edge of the filter for good measure. Oh, and the grease doesn't go just on the bottom, give it a good spray and squeeze out the excess. Then good luck getting the residual off your hands.:)
deej Jul 8, 2007 09:09 PM
http://i27.photobucket.com/albums/c1...cture_0161.jpg
They are both great products. The cleaner is so amazing, it makes any grease, dirt or whatever disapear, and the oil is super tacky. ;)
Gomerpile Jul 8, 2007 11:03 PM
The grease at the bottom of the filter is different than the filter oil. It is a much thicker grease than the filter oil. It is used specifically to seal the filter to the air box. I use Silkolene pro RG2 grease on the bottom edge of the filter after I degrease, clean and apply oil. (three products used to clean the filter)
gerrynolan Jul 8, 2007 11:39 PM
About how often should this 3 step process be done? Man I love my KLX!!!
Gomerpile Jul 8, 2007 11:46 PM
I check my air filter every few rides. If it looks dirty, than I clean it. It really depends on what type of riding you do and what mods you have. If you have your air box lid off and you ride all off road in a dusty environment, than you would probably want to clean it every other ride. The best way to tell if you need to clean it is to look at it.
warsanrotts Jul 8, 2007 11:48 PM
Speaking of air filters, what is everyone using instead of stock?
gerrynolan Jul 8, 2007 11:58 PM
ORIGINAL: Gomerpile
Thanks Man!
MaverickAus Jul 9, 2007 12:29 PM
ORIGINAL: warsanrottsSpeaking of air filters, what is everyone using instead of stock?
Stock
