Recommended way to break in fresh top end (351) and new bottom end rebuild?
I see a lot of differing opinions looking through some of the older threads when I searched. What's the general consensus right now?
I doubt you'll find a true consensus. I tend to be easy on any new run-in (I don't like the term "break-in", since I'm not trying to break anything) for a few miles, then, I gradually let the rpms increase for several miles. I turn it off and let it cool down. Start it back up, ride gently, then ride increasingly hard, so by the time the bike has 20-25 miles, it's seen WOT a few times. THEN I find the longest downhill around, and head down in a fairly low gear...rev it up to high rpms and get off the throttle and let the engine slow the bike down. Re-accelerate and back of the throttle for engine braking effect. Do this a few times.
At this point, I consider the bike 90% "run-in", and I ride it as I normally would. Sometimes I change the oil early, but, I do NOT change the filter early. Filters get more efficient as they get loaded with debris, but, it takes a LONG time for them to get loaded. I'll wait until the first filter change is specified by the manufacturer, and I'll change it then. I always cut it open to observe what the filter caught. Always some shavings in there. Never have these shavings been a shockingly large amount. Never had a bike or other vehicle that burned oil later. That doesn't mean what I tend to do is correct, either...it's just one general technique that one person has done. I hope yours goes well! |
I broke mine in doing a 65 mile single trail loop filled with hill climbs and rock fields.
Motor is perfect 5k later. |
There seems to be a consensus also that you should not let the engine "float" at high rpm: either it must be under load or braking hard. I would be curious to kow why...
Heat; would be my guess. No sustained hi loads[long up hill?]. I do four or five heat cycles, warm up ez ten minute ride then a complete cool down.:cool:
I still think this guy has the best take on the issue. I've used it with great success and no issues.
Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power |
Originally Posted by TNC
(Post 455383)
