Rebuild fork seal
When you guys are replacing you fork seals how often do you replace the clips and other hardware that goes with it?
Unless they are damaged from corrosion they don't need to be replaced. They aren't wear items.
When you mention "other hardware", are you talking the wipers also? You should always replace the wipers with new seals.
