Rear suspension service
When I installed my Racetech piston kit/valving in my '12, it was a simple system to overhaul. The only specialized equipment needed was a hypodermic needle adapter to vent/pressurize the reservoir.
I just used a bicycle suspension pump to fill the bladder and it's been perfect for over a decade.
When I did my rear suspension work, I used All ***** and Pivot Works parts for the swingarm pivot and linkage bearings and seal. Don't forget the shock oil(2.5 wt).
Everything you've highlighted will replace all of the wear components for the shock. Look at the swingarm bearings as well.
