Rear Suspension
Old Mar 31, 2006 | 08:30 AM
justin's Avatar
Default Rear Suspension
Tonight I adjusted the rear suspension. I weigh around 195 and noticed it needed some adjustments. So I tightened up the spring a little and played around with the rebound damping adjustment aswell as the compression damping adjuster on pg 125 & 126 in the manual. I noticed a big difference mostly by setting the rebound damping adjustment counter clockwise 10 clicks from the factory position. The manual said the suspension is set for a 150lb rider. So I recommend doing this to anyone who hasn't if your over 150 and beatin it up in the trails. You notice a big difference when the rear shock rebounds. Its alot quicker like it should be.
Old Apr 1, 2006 | 01:06 AM
bmwhd's Avatar
Default RE: Rear Suspension
That's the one area of the bike I've not messed with yet that I want to explore. I added compression to the rear spring but no other changes yet. At 210lbs, I'm sure I need to make some but I've never owned a bike with a real suspension (other than my BMW) so I'm a novice in this area.
Old Apr 1, 2006 | 01:17 AM
sdunne's Avatar
the compression and rebound only adjust to 16 turns out from fully seated position all clicks after that dont adjust anything. Right now Im running 4 clicks out comp in front, 10 clicks out comp rear, and 14 clicks out rebound rear.
Old Apr 1, 2006 | 01:18 AM
sdunne's Avatar
the compression and rebound only adjust to 16 clicks out from fully seated position all clicks after that dont adjust anything. Right now Im running 4 clicks out comp in front, 10 clicks out comp rear, and 14 clicks out rebound rear.
Old Apr 1, 2006 | 03:55 AM
justin's Avatar
todd at 210 you should bring out the rebound adjustment. Play around with it and see what feels right. you'll be glad you did. I hit some jumps today after work in the trails and it makes a more comfortable landing. so far my only complaint is the seat. What where they thinking for an enduro bike. After about 15-20 min my *** is killin me everyday and am now being forced into sitting further back on the seat. Can't wait till they come out with an after market. If anybody knows of a more comfortable seat, please let me no...
Old Apr 1, 2006 | 02:47 PM
crash's Avatar
Some company makes a gel seat for the drz 400 since it has a more uncomfortable seat than the klx. Would it work or maybe another aftermarket seat?
Old Apr 2, 2006 | 12:52 AM
sdunne's Avatar
Today I went ro the mx track With those suspension settings I described above. Bike reacted great I even over shot this table and landed at the end of the landing and just lightly bottomed. I wish I would have gotten pictures of that but just picture me a little higher and flying farther.
[IMG]local://upfiles/1071/1C24B73B79BA4EEC908B694B5BF568DA.jpg[/IMG]
Old Apr 2, 2006 | 06:43 AM
justin's Avatar
nice pic.. looks like a good old adrenaline rush. Ya the suspension is definatly sweet. How much do you way seth? Just wondering in comparison to my self. I haven't totally bottomed out yet by myself. I took my girl off roading the other day and bottomed out a lil, its really not meant for two to be hittin the trails but she loves it and had to share the rush..
Old Apr 2, 2006 | 06:49 AM
sdunne's Avatar
I fluxuate between 175 and 185 depending on how much I hit the gym right now Im 178
Old Apr 2, 2006 | 05:17 PM
incabiker's Avatar
Hey thats exactly how I flucturate sdunne, I'm exactly the same weight as you, so I will go dial these in the suspension right now.
Thanks again guys
