Rear sproket question.
Old Apr 4, 2007 | 12:59 AM
stainlessTT's Avatar
Default Rear sproket question.
What bike has the same size rear sproket? I want to order two sprokets from sprokets specailist with the Link Lock option. I want a 44th for the dirt and a 38 for the highway.
Old Apr 4, 2007 | 01:13 AM
Kawi Wawi's Avatar
Default RE: Rear sproket question.
Wow, going from 42 to 38 on the rear would make this bike extremely tall geared... (it's already geared tall with the 42t)
Sorry, nothing valuable to add here. Obviously you'll need two chains... What is this "link lock" option? Is it a quick change sprocket? How do you plan on swapping sprockets so easy? Most people swap the entire wheels (e.g. supermoto).
Old Apr 4, 2007 | 01:42 AM
kmarshall's Avatar
I believe you can use any of the klx300 rear sprockets. If you go larger than a 48t in the rear I don't believe you can use the chainguard. Hope that helps.
Old Apr 4, 2007 | 05:03 AM
TO: Kawi wawi - I run a 14-40 gearing now and think it is great. I do a lot of road riding and the gearing doesn't hurt me at all off road. I just want to have 1st as a granny low for really sticky situations. Check out the sprocet specialist web site to learn more about the link lock option...its pretty cool. I looked into getting another wheel assembly but don't feel like spending all that money.
To: kmarshall - Thanks, I thought that the klx300 would work.
Old Apr 4, 2007 | 10:57 AM
TeamKLX250's Avatar
The D-Tracker uses a 39 tooth so you may be able to get one not sure.
hokie01
May 29, 2008 04:09 PM
zzone
Aug 12, 2006 05:28 PM
zzone
Jun 16, 2006 05:45 PM
zzone
Jun 14, 2006 12:47 AM
Funkdock
May 11, 2006 04:09 PM
