Rear Axle Nut - how often to change?
Old Aug 27, 2017 | 06:20 AM
rprodrive's Avatar
Default Rear Axle Nut - how often to change?
Hi guys I am new here.
I have a 2015 KLX250S and took off the wheels so that a tyre shop can replace the tyres.
In the service manual it says when I put the rear wheel back on to REPLACE the rear axle nut. I imagine I need to order one from the dealer - but interested if you guys do that and if it is really needed?
Thank you
Old Aug 27, 2017 | 11:46 AM
Never replaced one in my lifetime. No way you're going to strip the threads or wear them out adjusting the chain or taking off the rear wheel a few times a year.
I don't remember if the 250 uses a castle nut or not. My KLX650 has a castle nut and drilled axle, and I use a hair pin cotter pin in it. It won't fall off.
Old Aug 27, 2017 | 12:37 PM
s10gto's Avatar
The Klx uses a locking nut. Axle is drilled but it only stops you from losing the nut. Just torque it to 81ftlbs and your good. I have had mine off a ton of times and has never been a issue.
Old Aug 27, 2017 | 09:55 PM
If there is a genuine concern, drill the nut and safety wire it.
Old Aug 28, 2017 | 03:33 AM
Interesting. I've never noticed that in any manual...but I guess I didn't look for axle nut replacement schedules. Working in a shop part time and owning tons of bikes...never replaced an axle nut due to a schedule. My '06 KLX with about 35K has the original nut. Never have seen it loosen.
This sounds like some kind of CYA lawyer BS.
Old Aug 28, 2017 | 11:43 AM
rprodrive's Avatar
You might be right about Kawasaki's lawyers! The reference is in the section on the wheel change - Section 10-10 "Replace the rear axle nut with a new one."
Old Aug 28, 2017 | 01:51 PM
You know those annoying lawyer ads that flood the airwaves during every commercial? I can see a new one.
From Dewey-Cheatem-& Howe Attorneys...Have you been injured in a motorcycle wreck due to old, dangerous, ineffective axle nuts coming loose resulting in injury, death, and mental anguish? If you have, we can find a way to blame someone else for your lack of service skills by having not replaced your axle nut every time you remove the rear wheel. Contact our office at 1-800-GET-CASH or online at kickintheaxlenuts.com. You could receive a big cash settlement by allowing us to screw someone else even if it was your own fault. If you call within the next 24 hours, you will receive a free Harbor Freight torque wrench which will us to assist you in additional lawsuits for inaccurate torque specs resulting in loose axle nuts and more cases of death, injury, and mental anguish. CALL NOW!!!
Old Aug 28, 2017 | 10:35 PM
If you would have bought KTMs you'd have only had a few hundred pounds of bikes... just ask 'em over at the ADVrider forum!
Old Aug 29, 2017 | 10:06 AM
reinigef's Avatar
Harbor Freight has torque wrenches on sale right now for $9.99. I couldn't believe I got my two for $19.99, who'd a thunk I paid twice as much. Dewey and Cheatem are OK but not sure about that Howe fella. My '14 doesn't have a castle nut but does have a hole in axle for a cotter pin, which I torqued down to 23 crispers per hectacre, is that correct?
Team FTB
Aug 27, 2017 12:36 PM
Malves
Jun 29, 2012 03:28 AM
danny1two3
Aug 1, 2007 08:29 AM
2001ninjaZX6R
Jul 20, 2006 07:02 AM
2001ninjaZX6R
Jul 20, 2006 06:55 AM
