quick turn throttle?
Old Sep 5, 2010 | 01:19 PM
neilaction's Avatar
Originally Posted by work
so neil im confused i see a single cable setup? how does that work? your telling me i can buy the kit you linked too and make it work on my 09? And how short is the turn with the vortex? I like the price of it.
Well mines on an 06 so I'm not 100% sure about the 09.
It's about a 1/4 turn and it only uses the pull cable.
I ditched the return cable altogether.
It's not an option i'd choose for highway use.
It's quite stiff and requires a fair bit of grip pressure to hold a steady throttle.
One day I'll look at reducing the tension of the carb return spring.
Great off road though.
Old Sep 5, 2010 | 01:32 PM
work's Avatar
that clarifies it thanks mate. so you used the stock cable?
Old Sep 5, 2010 | 02:01 PM
CousinLarry's Avatar
I use the Vortex, it's much better IMO. I rode a friend's without the Vortex and it reminded me of why I like the Vortex so much And yes work, stock cables.
Although I don't notice any extra grip pressure needed to hold the throttle, maybe I'm just used to it.
Old Sep 5, 2010 | 02:08 PM
work's Avatar
is your setup a single cable aswell?
Old Sep 5, 2010 | 02:32 PM
zomby woof's Avatar
I have the vortex, and it is single cable, stock pull cable. I also never noticed any difference in the force, or pressure required.
Old Sep 5, 2010 | 03:29 PM
Just order it. DOOO EEEET!
Old Sep 5, 2010 | 05:37 PM
work's Avatar
so the part number neil posted is the correct one right? and it comes with the assembly and throttle tube right? And i can use my stock cable? just wanna make sure before i get it.
Old Sep 6, 2010 | 12:44 PM
work's Avatar
just thought of this. how are you guys running your starter/ kill switch?
Old Sep 6, 2010 | 12:49 PM
neilaction's Avatar
The Votex doesn't affect there operation. It bolts on easily.
From memory I just had to cut the tube down a little.
Old Sep 6, 2010 | 12:56 PM
neilaction's Avatar
