Question about clutch replacement.
Old Jun 17, 2018 | 05:43 PM
deadelk's Avatar
Default Question about clutch replacement.
Can the clutch be replaced by just removing the clutch cover or, does the right side cover have to come off.
Thanks for the input.
Old Jun 17, 2018 | 08:23 PM
RaceGass's Avatar
I think you’ll need to use a screw driver to hold the rear brake lever out of the way, but just the cover needs removal not the side case. Remember to check you tube for vids. Katsumi mr duhfactor has a slipping clutch vid changing out clutch springs to heavier springs
Old Jun 18, 2018 | 06:07 AM
outrecording's Avatar
Yeah, just remove the clutch cover. On the other side you’ll have to remove the inspection plug to get a socket in there to hold the flywheel bolt to keep everything from spinning as your try to loosen the clutch hub nut.
I’d grab an a klx membership from cyclepedia.com if you have the spare cash. It’s great for walking you through stuff like this. It’s all I referenced the first time I put in a new clutch.
Old Jun 20, 2018 | 11:46 PM
deadelk's Avatar
Judder spring, yes or no?
Old Jun 21, 2018 | 06:10 PM
RaceGass's Avatar
Iirc the ebc clutch plates I installed didn’t reuse the judder spring. Since it has less surface friction area compared to the other plates I didn’t give it a thought.
I always wondered what exactly that contraption actually did
Old Jun 21, 2018 | 06:27 PM
You asked me about this a number of years ago. https://www.kawasakiforums.com/forum...e2/#post460964
Old Jun 21, 2018 | 06:38 PM
RaceGass's Avatar
A few years back for sure. That was one long thread!
Old Jun 23, 2018 | 12:58 AM
danpluso's Avatar
Not sure if this will help but I was watching this video just the other night. I really like this guy's channel. Skip to around the 4:00 mark.
Old Jun 23, 2018 | 06:14 PM
RaceGass's Avatar
heres another which involves installing stronger Barnett clutch springs
Einfahrt
Apr 9, 2014 01:33 PM
Illking
Jul 30, 2013 10:49 PM
cegusman
Apr 9, 2013 02:52 AM
kawadude
Sep 2, 2009 11:56 PM
