Pics of my oil leak
Old 11-18-2007, 09:40 AM
chris72a's Avatar
Default RE: Pics of my oil leak
Hey Dragone#19,
I Hope it is chain lube, I didn't put any on other than what the dealer did, I'm more thinking it is either a manufacturing fault or an assembly issue, the bikes only are a couple days old and only done 44k'ms, about 30miles I think so the seals are all brand new. The other thing I've noticed is if I put it on a stand the oil doesn't leak but if I use the bike stand it drips down obviously because the oil is flowing to the side of the lean. I'm just taking the bash plate off and gonna clean it real good so I can see the oil. Now just gotta find some foot powder!!!
Cheers
Chris.
Old 11-18-2007, 09:43 AM
ORIGINAL: tremor38
My guess is the seal was defective from thegit-go or they damaged it during assembly.
and that is quite possible as well.
Old 11-18-2007, 09:56 AM
chris72a's Avatar
Hey Guys,
If it is the seal do you know if it is a big job to fix or something that can be done ina couple of hours.
Cheers
Chris
Old 11-18-2007, 10:34 AM
tremor38's Avatar
If they have the part on hand (one O-ring), the job is less than one hour. It involvesremoving the front srocketandpulling the output shaft sleeve to replace an O-ring that is under that sleeve.
From what you said, I'm assuming the leak is coming from the output shaft. Hopefully that will fix it, because otherwise you're talking about splitting the case and replacing the oil seal.
ORIGINAL: chris72a
Hey Guys,
Cheers
Chris
Old 11-18-2007, 10:37 AM
chris72a's Avatar
Thanks Tremor38
I'm feeling a bit better now, I am nearly sure that is where it is coming from. I would hope the dealer has the O-Ring in stock.
Cheers
CHris.
Old 11-18-2007, 11:43 AM
tremor you think it will only take an hour to remove the ouputshaft.... i highly doubt that...how do you remove it? you maybe looking at a big tear down to get to that....
Old 11-18-2007, 11:59 AM
vlodpg's Avatar
PAGING DEEJ, PAGING MR DEEJ:
Dirty motorcycle cleanup in isle 4
Old 11-18-2007, 12:15 PM
chris72a's Avatar
hey vlodpj,
it wasn't like that for long
First time it ever got dirty to but it was great fun!!!!
Cheers
Chris.
Old 11-18-2007, 03:39 PM
KLXer's Avatar
I dont know how the KLX works but I have replaced a few countershaft seals. No need to remove the shaft, just remove sprocket, pull old seal, put new one on.
Edit: Just looked at the parts diagram, looks no different than what I expected, dont see why the above procedure is not the case.
Old 11-18-2007, 03:44 PM
vlodpg's Avatar
ORIGINAL: chris72a
hey vlodpg,
Cheers
Chris.
I think I read somewhere that he has 2 bikes, 1 that is showroom clean & one he rides. Mine is awaiting the skid plate & 13T fromt sproket arrival before it plays in the dirt!
Quick Reply: Pics of my oil leak
