Pics of my oil leak
Pics of my oil leak
Hi Guys, this really sux, if you read my other post about the oil leak, here is a couple of pics to follow up.
The oil window is still saying full. obviously however there is oil coming from somewhere, I now have 44km's on the bike, it is going back to dealer tommorrow, hopefully they can find the leak and fix before the weekend.
Any comments appreciated.
Cheers
Chris.
Cheers
Chris.
RE: Pics of my oil leak
Thanks Dragone,
cleaned after I took the pics, just wanted the pics for some extra proof for the dealer as the leak is a lot more obvious when combined with some dirt.
Cheers
Chris.
Cheers
Chris.
now that it's clean you can spray it with some aerosol foot powder and run it a little bit and then look to see where it originates, it will leave a trail in the powder
Taking the skid plate out of the way will allow you to see things a lot easier when you do the leak check.
ORIGINAL: yoman1
Thanks All,
It seems to be coming from the front sprocket, I just took the sprocket cover off and it seems to be running down a little ridge and along the frame down to the little bash plate cover.. I haven't heard of the powder but will try tommorrow, I can't run it at the moment. the oil is no higher than the sprocket so it is sprocket height or below. My biggest concern is that it will be a major fix and the dealer will take a long time to fix.
Cheers
Chris.
Cheers
Chris.
I like the powder idea. Sounds like it would work too. My thinking is chain lube as a first thought. Causes a mess running down the case at the CS. Why my Q on cleaning to see what may be causing the issue. Yes, seals go bad because of age or grime. Again, curious as to what it is.
