-   -   Order my big 300R parts (https://www.kawasakiforums.com/forum/klx-250s-71/order-my-big-300r-parts-26372/)
buffalony Jan 6, 2009 04:49 PM
I called the dealer today and ordered everything I need to upgrade my bike to a 300cc.
I use my bike alot for purposes other than play. I decided to just go with the stock kawi parts for those just in case moments if something happens to the engine, parts will be easy to find.
Dealer is going to install it for me for 850 +tax, that includes parts.
My Dyno Jet kit will be delivered tomorrow.
That will put my mod list to
300cc/BG full exhaust/Dyno Jet Carb kit for 300 Stage 2/KDX Snorkle/K&N Air Filter/ Fly Racing Bars(Gold)/ Folding Mirror(Still need to order)/Removed Smog crap
Anybody know what carb is on the 2007 300R? Was just curious. it is a different part number, which means it must be different in some way to the cvk34 right?
MaverickAus Jan 6, 2009 06:39 PM
http://www.kawasaki-motorcycle.net/2007-klx-300r.php
34mm Semi-flat Slide CVK Carburetor
- Precisely meters for good fuel economy
- Provides quick throttle response
buffalony Jan 6, 2009 07:17 PM
I wonder if the difference is in the slide?
tremor38 Jan 7, 2009 10:39 AM
Same carb (CVK34)..it's just misleading advertisment hype. If you look at the slide shape, yeah, you could stretch it a bit and say "semi-flat slide" if there's such a thing ;) ....but that has no bearing on throttle response.
Any way you want to slice it, the slide is still moved by engine vacuum, so there's no way it's anywhere near as quick as directly moving the slide with the throttle cable/s....which is what most people think of when you use the term 'flat slide carb'
Very 'slick willy' type advertising on Kawi's part. ;)
