An oil thread?! You've got to be kidding me...
Just thought I'd share my find.
It's winter, it's really cold, and I'm still riding. Ran the bike mostly on 10W-40 for it's life, switched to Rotella 15W-40 this past spring. Perfectly happy. Since it's getting a little cold to turn over 15W, I thought I'd do some reading of the back of the oil containers, looking for the JASO-MA certification in a lighter oil. Noticed a liter of Rotella 5W-40 synthetic and sure enough it's JASO-MA. I think I found my winter oil. I'll report back when I need to start her up on a 0-10ºF morning. |
I'd bet a nickel that you'll have no problems at all. If my 400+ hp hemi can run 5W-20 in the heat of the summer, I'm sure 5W-40 for the ol' KLX in winter should be fine.
That oil is a good choice year round
I use the 5w-40 in both of my other bikes for almost 10 years now-great stuff. I would run it in the KLX but for some reason EBC doesn't want you to use synthetic on their clutch plates so it's the regular Rotella.
I just look for the JASO-MA, just because. Who really knows if it makes a difference in engine life, but I figure for me at the price of Rotella it isn't worth not running it.
Until someone (don't look for me to do it) actually does the full on test, running comparable engines on oils until they blow up or they do the Consumer's Reports type test doing a tear down and measurement to start and then to finish after a bazillion miles to see what the wear actually is, we'll never actually know. We'll just all do whatever we want... and that's fine with me. |
I was running the rotella 5-40 t6 when my exhaust cam melted into the head. Certainly can't say it was the oil, but there was oil getting to the head when this happened.
also worth noting, I did not put the big bore kit in myself so I have no idea what really caused it, I'm still a little weary of running 5-40 at least in the warmer weather. Stocked up on some Kawi 10-40, fingers crossed. |
Originally Posted by wreckster
(Post 517053)
also worth noting, I did not put the big bore kit in myself so I have no idea what really caused it, I'm still a little weary of running 5-40 at least in the warmer weather. Stocked up on some Kawi 10-40, fingers crossed. One point to your comments on the oil weight - 40 is 40 within the oil industry specs, making the 5w40 perform the same as the 10w40 at full operating temperature. But I do understand the reservation when one has had problems when using some products. |
Finally broke down and read an oil thread - this one.. I expected more laughs..
Oil is not a funny subject... unless you slip in a puddle of it and fall on your butt and your buddy posts a video of it on YouTube! _:eek: _:D
Maybe we need an oil dry thread! Is cat litter better? Saw dust? oil-dry? pads? left over diapers? Maybe reference a few Brit and HD forum links... :rolleyes: |
Originally Posted by TNC
(Post 517005)
Too far off topic??? Point is, with the advancements in oils we could be running 0W5 in a few years. Who knows? Happy new year KLXers! |
