OEM part numbers
I want to do the 300 kit up grade to my 07 klx 250s.I want to use factory OEM parts. Can anyone give the correct Kawasaki part numbers for the cylinder the piston and the ring set?Are they the some numbers listed for the 07 klx 300r? Thanks for the help.
Originally Posted by hirum
(Post 355788)
Why won't you consider a larger displacement option? The cost difference is negligible isn't it? :confused:
OEM parts
Thank you guys for your help.Hope to get this done before spring. Hirum
