Non starting cold weather/maybe answer
I may have a fix for that problem. Drove my bike into my shed. it stayed 3 weeks. yesterday would not start. (the short story)injected small amount of gas into the backfire screen. (That french word) Wala. started second turn over. What be happening?? The gas maybe evapoating out of the fuel bowl/ to a level that is below the starting circuit. the fuel valve has to have a vaccum to allow gas to go through the valve. No prime on circuit in valve. Had similar problem different machine. Someone try it next time. Wondering if the over flow line may not be a good place to inject a little fuel/ leaving the seat on?
Carlb
KLX250s
1997 dr650
Carlb
KLX250s
1997 dr650
ORIGINAL: CarlB
Carlb
KLX250s
1997 dr650
[/quote]
I have had the same problem since I got the bike. Even killed the battery a couple of times. It happens to me if the bike is just cold, as in not run fro a day or two. Even ambient temps of 60 degrees and warmer. I find this to be very annoying! One response I got early on is pull the choke ALL the way out where one has to hold it.
I have done all the mods for jetting and such but it just cold starts hard! After wrmed up it's fine.
Not real in favor of draining the bowl and hard to believe the fuel goes bad in a week.
Any other idea's?
Any other idea's?
markmeinteil
Oct 19, 2006 06:03 AM
