No headlight or taillight ??
Deej
They are AGC-10 amp fuses. There is a small rubber shroud that you have to slide off the fuse box to gain access to it. That rubber shroud comes with a spare fuse embedded in it. So if your ever in a pinch you can use that one.
Mike
Mike
Hi All.
Must be a fuse on my 2007 KLX 250. Under the seat are 3 connectors and a couple other wires. Low light and cold here. Please let me know where to look. Shakey w/cold. I'll try again after your reply.
Sincerely M.
In mid April I got it fixed. Dead easy. Main fuse ( yellow ) is a modern car type 20 Amp. The other two old style ( glass ) 10 Amp fuses were ok.
That's Us building new trail. ( near to Algonquin Park in Ontario Canada )
Sincerely M.
Thanks All.
Would you give a more detailed descrip of which cable/ connector I am looking at? ( for the main starter fuse )
There is but a black taped bunch of wiring coming up over the back inner fender. They are very tightly packed. Advice on doing the least damage as I try to replace that 20Amp fuse?
Thanks again
M
Thanks again
M
