-   -   Ninja 250 Lever compatibility? (https://www.kawasakiforums.com/forum/klx-250s-71/ninja-250-lever-compatibility-42125/)
Chay Jun 24, 2014 06:42 AM
Been trying to hunt down a pair of shorty levers for my 09 klx250s, I hear from scattered sources that Ninja 250 levers bolt right up. Do you think these levers would? US SHIP 1 Pair Brake Clutch Levers for Kawasaki Ninja 250R 2008 2012 09 10 11 | eBay
There is a review of their quality and they are pretty good, and at 28 bucks it would be a fairly easy hit to take if they break/dont work. Have any of you guys fitted anything like this before?
Brio Jun 24, 2014 09:20 AM
They will fit for sure.
I got these ones and i'm very pleased with them.
smadi Jun 24, 2014 10:07 AM
Can those levers be changed between regular and short length whenever you want?
Is it a pain?
Pros/cons of those levers?
I'm considering getting some.
klx678 Jun 24, 2014 11:44 AM
If you're buying them because others have or for "style" you are doing it for the wrong reason.
One reason for short levers is to avoid breaking them when the bike goes down. Long levers stick out far enough they will frequently break or bend when the bike falls over or is crashed. Short levers won't hit as readily. Before the shorties it wasn't uncommon to see off-roaders with broken clutch and brake levers.
Another reason is if, like many racers and riders, you only use two or three fingers on the levers. You will not hit or pinch the fingers still holding the grips.
Last reason I can think of would be to fit in bark busters that fasten to the end of the bars, most will not fit full length levers and could pinch fingers between them and levers. I had to cut my clutch lever more, because my one finger would pinch at the outside end, between the end of the lever and the guard bar.
I use a three finger grip on my clutch and two on the brake, so short levers absolutely make sense for me. Fact is I use the same grip on street bikes, but I don't use cut levers on them because they need the ball end.
There would be no reason to swap between the two if there is a true need for them.
Chay Jun 24, 2014 02:52 PM
I don't think we have to justify what we outfit these little bikes with. If they look cool and that's why you get them, that's perfectly fine. That being said, a friend of mine had them on his tiger and when i rode it, I loved the levers. Not to be confrontational, but I have seen you floating around in my short time here and you tend to have a negative standpoint. Lastly, the guy was talking about the pair that were posted by the other user here, they have adjustable length to go from shorty to long, he was just asking if it was a pain to adjust the length. This is a feature of those levers, so it was entirely justified and pertinent for him to ask how hard it is to swap.
donaldor Jun 24, 2014 03:45 PM
Don't talk back to your father like that!
donaldor Jun 24, 2014 03:46 PM
I dig those Ninja levers. They are exactly what I've been looking for.
durielk Jun 24, 2014 06:33 PM
Using the Ninja levers, does it maintain the clutch/starter interlock, or does that interface need to be disabled?
Brieninsac Jun 24, 2014 07:38 PM
They look a little different then mine, but it might just be the picture. I paid about the same on eBay too.
Short Black Brake Clutch Levers for Kawasaki Ninja 250R 2008 2011 CNC | eBay
One thing to keep in mind, they have a little more wiggle so if you can use a thin washer it will help.
Oh ya, it works with the clutch kill switch.
durielk Jun 24, 2014 08:11 PM
thanks, how come they don't have green????? :(
