New rear Caliper?
Old Mar 11, 2021 | 04:38 PM
MarcMénard's Avatar
Default New rear Caliper?
GoodDay.
Looking for an after market 2007 KLX250s rear caliper. A price for a complete one and where I can order it new.
OEM here ( Canada ) says 225.00US. Is that a good price? OEM rotor is about 200.00US. good price?
An OEM piston ( for that caliper ) is 60.00US
2007 KLX 250s rear rotor that I see on Ebay at around 60.00US mailed to me in Canada. Is it a quality item? ( The one pic on Ebay shows a 6 bolt rotor. Is that correct? )
Let me know if You have a good used one.
Needed Yesterday.
BeWell M
Old Mar 11, 2021 | 09:09 PM
You can use any of the KLX calipers from the 94 KLX250 on up. Fact is from the carriers I think there are KX calipers which would work too. Only difference I've seen was the caliper carrier. I'd think you could find a used one for reasonable money. The numbers will change based on color, finish or other details.
The reason I know this is because your carrier for the caliper is as follows:This Kawasaki 14079-1105 HOLDER-ASSY,REAR CALIPER fits the following models and components:
Aftermarket Parts Brake Brake Calipers Front & Rear Brake Calipers
Kawasaki Motorcycle 1996 KLX650R - KLX650-D1 Rear Brake
Kawasaki Motorcycle 1996 KX250 - KX250-K3 Rear Brake
Kawasaki Motorcycle 2000 KLX300R - KLX300-A5 Rear Brake
Kawasaki Motorcycle 2002 KX500 - KX500-E14 Rear Brake
Kawasaki Motorcycle 1997 KX500 - KX500-E9 Rear Brake
Kawasaki Motorcycle 1997 KLX300R - KLX300-A2 Rear Brake
Kawasaki Motorcycle 1995 KX125 - KX125-K2 Rear Brake
Kawasaki Motorcycle 2007 KLX250S - KLX250H7F Rear Brake
Kawasaki Motorcycle 2001 KLX300R - KLX300-A6 Rear Brake
Kawasaki Motorcycle 2000 KX500 - KX500-E12 Rear Brake
Kawasaki Motorcycle 2006 KLX250S - KLX250H6F Rear Brake
Kawasaki Motorcycle 2001 KX500 - KX500-E13 Rear Brake
Kawasaki Motorcycle 2005 KLX300R - KLX300-A10 Rear Brake
Kawasaki Motorcycle 1995 KX250 - KX250-K2 Rear Brake
Kawasaki Motorcycle 1996 KX125 - KX125-K3 Rear Brake
Kawasaki Motorcycle 1999 KX500 - KX500-E11 Rear Brake
Kawasaki Motorcycle 1998 KLX300R - KLX300-A3 Rear Brake
Kawasaki Motorcycle 2006 KLX300R - KLX300A6F Rear Brake
Kawasaki Motorcycle 1998 KX500 - KX500-E10 Rear Brake
Kawasaki Motorcycle 1999 KLX300R - KLX300-A4 Rear Brake
Kawasaki Motorcycle 2007 KLX300R - KLX300A7F Rear Brake
Kawasaki Motorcycle 2003 KLX300R - KLX300-A8 Rear Brake(KLX300-A7/A8)
Kawasaki Motorcycle 2002 KLX300R - KLX300-A7 Rear Brake(KLX300-A7/A8)
Kawasaki Motorcycle 2004 KLX300R - KLX300-A9 Rear Brake(KLX300-A9)
Kawasaki Motorcycle 2003 KX500 - KX500-E15 Rear Brake(KX500-E15)
Kawasaki Motorcycle 2004 KX500 - KX500-E16 Rear Brake(KX500-E16)
Kawasaki Motorcycle 1996 KX500 - KX500-E8 Rear Brake(KX500-E8)
I found this one on ebay.ca click here Use your carrier for it, as said, the rotors from 2009 up are 240mm, where yours and others before that are 220.. At the price you could buy a rebuild kit with new seals and do it up, but I'm betting the caliper will be fine as is. Fact is I did a swap with a Canadian, where he sent me his pre-09 rear caliper/carrier, I swapped out the carriers and sent my carrier with his caliper back to him. He wanted the larger 240mm rotor where I wanted the smaller 220mm rotor. Caliper were physically the same.
As for rear rotors, again any KLX250/300 and some KDX200/220 from 1994 to 2008 will work, the 220mm. 2009 and later used a 240mm with a different carrier. I am running a KLX300 rear rotor with a 2007 caliper carrier on my 2009 KLX. The rotors are six bolt I believe I paid around $30 usd for the used 300 rotor. I looked on ebay, pickings are pretty thin there. I also have a 300 front rotor on the bike too and bought a back up 300 rotor for $20 usd on ebay.
Found this KLX rear rotor click here
Old Mar 11, 2021 | 09:52 PM
MarcMénard's Avatar
Hey KLX678 Thank YOU.
Thanks Partzilla shopping cart 167.00US for the small stuff I think I'll need. Plus 32.99.00US shipping.
Hmm? Almost the same as my dealer over here.
Thanks again. M
gronk
Mar 4, 2020 11:11 AM
prakthad
Feb 6, 2019 07:44 PM
andyng
Feb 9, 2018 02:18 PM
hounderd
Jul 4, 2014 01:33 AM
klx678
Jan 30, 2014 10:01 PM
