New to me 09 KLX250s
Hello all, I have a 2009 KLX250s that's been sitting in a barn for about 5 years. Got it for a good price, and it's only got 940 miles on it. I drained and put in new gas, put a battery in it, and gave it a shot. No luck. It'll start on starting fluid. I'm going to pull the carb and clean the jets all out, the gas was left 'on' so I'm assuming the jets are clogged solid. In the meantime, I have been reading a bunch of posts about opening this little thumper up, and I haven't found one yet that covers the setup I can afford this summer. I'm thinking that since I have the carb off I might as well get the 2152 jet kit from DJ, and add a KDX200 snorkel. BUT, I don't have the $$ for an exhaust, and honestly don't want loud anyways. I've read a bunch and am actively looking for a KLX300 exhaust, but until then, I think I'll end up just doing the 1/2" drill through the first plate on the stock exhaust. I live in a hilly area, my riding will generally be between 700-1500 feet above sea level. I grew up on dirt bikes, switched to the street at 16, and am now back into the dirt at 47, my boys just moved up from crf50's to 110's, so it's time for me to have some fun too!
SO my question to you gurus is with a DJ jet kit, a KDX200 snorkel probably a Uni air filter, and a modded stock exhaust, should I go with the stage 1 or stage 2 setup of the jet kit? Thanks for any and all input! |
IMO, if your not rac'in, why change the muffler?
Originally Posted by durielk
(Post 546215)
I bought a 2009 KLX250S last year with only 900 miles on it. It was properly stored and starts and runs like a brand new bike. Sorry to hear that yours wasn't stored properly, but all hope is not lost. As you mentioned the carb will need attention.
The only mod that I have on my bike is the K&N air filter that was installed by the previous owner. I suspect that the carb may have had a jet kit installed but I'm not sure because the Welch plug that gives access to the mixture screw has not been removed. I live and ride at the 4500' level so what is lean jetting at sea level may work very well where I live. Bike starts well even in cooler temperatures. Still have the stock exhaust, but like you am looking for a deal on a klx300 exhaust. As far as drilling the stock exhaust: I live in the west in an area where forest fires are common. If a Ranger was to test the exhaust by inserting a check rod I want to make sure that I'm legal. Drilling the exhaust might get me into trouble with the law so I'm cool with the stock setup. BTW- I'm a lot older than you and sold my last Dualsport, a Suzuki DR350S in 1994, so it's great to be doing off-road again. It hurts a little more to fall nowadays so I try to keep falling off to a minimum! |
Put a new plug in it,
. Gap at your own risk |
the dj kit gives you a good needle. the stock needle is too lean. pilot, needle and the stock 118 main is too lean even for your elevation. I have not done the dj kit ...... yet. I put a 40 pilot 2 turns out on the fuel screw, and I just put in a 135 main. I have the N1TC needle in there too. 135 might be too rich for you though. I just didnt want to drill my slide yet, which I think is part of doing the dj kit installation. if it pops over on starting fluid its probably your carb.
you could just do a 128ish main, a 38 pilot and a N1TC needle with the circlip on the top groove. the fs should be 1.75 turns out from the factory under that alum plug. I pulled the plug to get to the screw. |
Originally Posted by ctbale
(Post 546225)
I just didnt want to drill my slide yet, which I think is part of doing the dj kit installation. you could just do a 128ish main, a 38 pilot and a N1TC needle with the circlip on the top groove. the fs should be 1.75 turns out from the factory under that alum plug. I pulled the plug to get to the screw.
I have a FMF Power Core 4. But its too loud for my "sleepy" little town of 400 people. I have a stock slip on coming in about a week. I need to read up on where to drill that 1/2" hole. sounds like a good idea due to stock muff being really restrictive.
If I was going to do it again I might think about the DJ kit. The needle is what I really want off that kit. But I don't like the idea of drilling the carb slide. I always like to be able to reverse anything I can do. And the only way you can reverse that is I read to epoxy the whole up and re-drill it to the stock size. If you do the N1TC Needle dont forget to order the clip and the collar. part numbers are on this site somewhere. the EPA plug is a must do mod. just drill the alum plug with a small bit, but go slow, dont want to hit the brass fuel screw under the plug. If your at 1000 ft you might want to go 38 on that pilot jet and 2.25 turns out. you can go to 3 turns out max before you jump to the next richer jet (40) |
(Post 546231)
If I was going to do it again I might think about the DJ kit. The needle is what I really want off that kit. But I don't like the idea of drilling the carb slide. I always like to be able to reverse anything I can do. And the only way you can reverse that is I read to epoxy the whole up and re-drill it to the stock size. If you do the N1TC Needle dont forget to order the clip and the collar. part numbers are on this site somewhere. the EPA plug is a must do mod. just drill the alum plug with a small bit, but go slow, dont want to hit the brass fuel screw under the plug. If your at 1000 ft you might want to go 38 on that pilot jet and 2.25 turns out. you can go to 3 turns out max before you jump to the next richer jet (40) I'll be drilling out the EPA plug next week, busy weekend coming up. Zero bike time. |
(Post 546231)
On the down side, the DJ kit doesn't come with a pilot jet at all. I guess they leave it stock. I'll grab one and up it. |
