New Handle Bars
So i took my first tumble today on the KLX, nothing major a slow speed downhill slide and the bike fell from beneath me. The left side of the handle bar stuck in the ground causing the slight bend.
I Heard the stock bars are not very strong for things like this... as i found out the hard way
Now the time has come to upgrade the handle bars, what size of bar would fit the klx without having the extend any cable etc?
I've rode with renthals in the past on old bikes but do like the idea of pro tapers.
all help is appreciated thanks guys
I bought a set of renthals Cr high bar, these appear to have a similar bend height etc as the stock handle bar
I tried to swap the old bars for the new and came across a slight problem, the stock bars have holes in them for the controls to slip into, so they dont twist?
how did you guys get around this when you fitted your bars?
Thanks again guys.
Thanks again guys.
I had cr hi pro tapers installed, the answer adapters raised the bars up abit. Cable lengths were acceptable. The wife liked it since the forks could be raised up in the triple clamps which helped on the street but didnt help out off road. The answer adapters space out the handle bar clamping surfaces, which doesn't work out with the Scott's stabilizer, and 7/8" rentals had to go back on to run it.
Thanks
I just ordered some pro taper se kx high bars a few days ago. I did some research and everyone says these are the highest bars you can fit on our klx's without having to get longer cables. Also ordered some msr bark busters. Im taking a big 2 week trip on my klx and dont want to bend my bars anymore than they already are.
