My version of the auxilary tank!
Old Aug 17, 2009 | 07:32 PM
dualsportman's Avatar
Default My version of the auxilary tank!
Hi there!
Here are some pics of my gas tank! and the fitings...
The rack is a Nomandic..
The problem with this setup is I would prefer something that would rapid to remove the gas thank mount without removing the hole rack for shorter trip. Any ideas?
With the Nomandic rack, we can not install a Pack Mount...
Thanks
Eric
Attached Thumbnails My version of the auxilary tank!-gaz-002.jpg   My version of the auxilary tank!-filter-003.jpg   My version of the auxilary tank!-filter-002.jpg   My version of the auxilary tank!-filter-001.jpg   My version of the auxilary tank!-gaz-001.jpg
Old Aug 17, 2009 | 08:05 PM
Didn't you get the quick release with it? I thought I saw it somewhere.
Old Aug 17, 2009 | 08:07 PM
http://www.kolpinpowersports.com/fue...ernatives.html
There is supposed to be a black 1/4 turn handle system.
Old Aug 18, 2009 | 12:30 AM
WestOzKLX's Avatar
That'll work.
Old Aug 18, 2009 | 12:52 AM
KDXmike's Avatar
I'd hate to see that long bolt sting you in the back in the event of a mishap on the trail. Hope you remove it when the tank's not in use.
As Deej said, there should have been a fastening mechanism that came with the tank. Good luck with it.
M
Old Aug 18, 2009 | 01:09 AM
neilaction's Avatar
I'm sorry but these pictures crack me up.
Old Aug 18, 2009 | 01:38 AM
North/South's Avatar
Nice try to install this tank on the cheap. I would recommend that you get the real tank mount from either Kolpin or Rotopax. Weld on tabs, or put flat bar below the cross bars on the rack, then bolt on the mount with four bolts. Also remove the tank mount by taking off the four bolts. Put it back on whenever you need it.
Old Aug 18, 2009 | 01:52 AM
c_m_shooter's Avatar
I settled for two MSR fuel bottles on mine. This is the only pic I have handy.
Old Aug 18, 2009 | 11:03 PM
DSBoomerRider's Avatar
That's one way to do it
Old Aug 19, 2009 | 12:35 AM
"Git-R-Done"
