Motion pro vortex throttle question.
Old Jan 31, 2008 | 10:57 PM
2k1w=no$'s Avatar
Default Motion pro vortex throttle question.
Is there only one vortex throttle. I am placing a order at dennis kirk and they have a motion pro vortex throttle in there, it dosen't say anything about being a 1/4 or not. I don't want to get the wrong one.
Old Jan 31, 2008 | 11:16 PM
bryantjt's Avatar
Default RE: Motion pro vortex throttle question.
Should be it, its called the Vortex race throttle or some such.
Part number 01-0054 is the part number I have, which is what DK shows, so you should be good to go.
Old Jan 31, 2008 | 11:18 PM
TypeSH's Avatar
Yes, there is only one vortex and you will love it. Great mod!!
http://www.motionpro.com/motorcycle/...rtex_throttle/
Old Jan 31, 2008 | 11:26 PM
2k1w=no$'s Avatar
Thanks.
Old Feb 1, 2008 | 12:11 AM
Bad Bear's Avatar
when you use this throttle does the stock pull cable work or do you need another cable Thanks
Old Feb 1, 2008 | 12:13 AM
Bad Bear's Avatar
Dennis Kirk wants more for it that Motin Pro that is strange
Old Feb 1, 2008 | 12:20 AM
lcpl0331's Avatar
the stock cable works.
Old Feb 1, 2008 | 01:03 AM
Bad Bear's Avatar
THANKS
Old Feb 1, 2008 | 03:34 AM
VORTECkaw's Avatar
just wondering what advantage you get from this? thanks
Old Feb 1, 2008 | 03:38 AM
bryantjt's Avatar
The throttle opens fully in a quarter turn instead of a half turn. And it doesn't bind like the stock setup that uses the 2 cables. I had to have a lot of slop in my stock setup so it wouldn't bind when turning right, no issues with the Vortex single cable.
