Motion Pro clutch cable (03-0389) too long? How to reroute?
Old Nov 11, 2023 | 03:27 AM
ednerd's Avatar
Default Motion Pro clutch cable (03-0389) too long? How to reroute?
I got this as a replacement and I am having a tough time adjusting it to pull the actuator arm enough to disengage. Is there a way to reroute the cable to take up some slack? Adjusters at the lever and mid cable are maxed. Help? And thanks in advance.
2014 351s with ProTaper KX Hi 7/8
Old Nov 14, 2023 | 08:31 PM
ednerd's Avatar
Default Clutch Cable Routing and Adjustment
Is this cable just too long?
Does this routing look right?
Are there any other adjustment points that I am missing?
File Type: mpg
Old Nov 18, 2023 | 10:35 PM
onebus's Avatar
Hi:
The length of the overall cable doesnt matter. The outer casing seems to be too long not allowing the inner cable to move as it should. In the video, I notice something in the cable just behind past the bracket at the engine. It seems to look like the outer casing crunched up, is that there or am I just seeing it that way.
Old Nov 19, 2023 | 07:24 PM
ednerd's Avatar
Thanks for the reply. And, yeah that part looks scrunched but it isn’t the normal outer casing. I’ll take the cable out again for closer inspection.
Originally Posted by onebus
Hi:
Old Nov 20, 2023 | 09:51 PM
onebus's Avatar
The routing of the cable has no affect on the movement or the throw of the cable If it were 100 feet long and wraped up in coils it would still perform properly when adjusted. On the center cable adjustment, if you move it all the way in oposite way, does it make a difference
Old Nov 29, 2023 | 02:17 PM
kageyb's Avatar
The mentioned crumpled cable housing would make the housing too short and not allow the adjustment points to correctly set the length of the housing. You'll need to exchange your defective unit for a new one.
alky
Mar 28, 2017 06:16 PM
stephenmarklay
Jun 11, 2012 02:06 AM
GaryC
Jan 18, 2012 12:54 AM
punkenduro09
Apr 11, 2011 04:29 AM
FlyBoy276
Jun 26, 2008 01:09 AM
