Mikuni tm ??
Old Oct 3, 2010 | 08:31 PM
work's Avatar
Default Mikuni tm ??
Im sure this has been covered a million times ive searched and cant come up with what i need.
Will the mikuni tm33 pumper mount up too are spigots? and whats needed to make the throttle cables work? with it being 33mm instead of 34mm will this hurt me? or with proper jetting pump setup will it not matter?
Old Oct 3, 2010 | 10:39 PM
neilaction's Avatar
Will the mikuni tm33 pumper mount up too are spigots? YES and whats needed to make the throttle cables work? Stock pull cable works fine, return cable is not used, with it being 33mm instead of 34mm will this hurt me? 33 will be OK. Its the pump action your looking for or with proper jetting pump setup will it not matter?
I got the BB 33 bored out to 34.
Bolted up without any problems.
It did come with a custom throttle cable bracket so I'm not sure how easy it fits without this BB addition.
Old Oct 3, 2010 | 11:31 PM
work's Avatar
easy enough found a good deal on one on egay. wonder if bb will sell me just the cable bracket? was it a pita to setup? Thanks mate.
Old Oct 4, 2010 | 03:31 AM
FlyingFinn's Avatar
If you buy a generic TM33 just send the throttle cable bracket to B.B so he can modify it for you. The bracket must be cut&welded to make it fit the KLX.
In it's stock form a TM33 will not fit.
Old Oct 4, 2010 | 05:31 AM
slippery750's Avatar
I think Bill puts the carb boot adapter on the TM to fit the stock boot. Not sure though.
Old Oct 4, 2010 | 09:03 AM
neilapples's Avatar
Just buy a tm36-68 instead…… its an easy fit, just plug and play.... no modification’s necessary…..
Old Oct 4, 2010 | 11:12 AM
work's Avatar
are there any threads showing this? a 36mm wouldnt be too much?
Old Oct 4, 2010 | 10:19 PM
neilapples's Avatar
yeah, there are a few threads... just do a search for TM36-68.
here's a link to a thread that I wrote in while I was installing mine.
https://www.kawasakiforums.com/forum...ad.php?t=33010
The Tm36-68 fits better than the stock carb and doesn’t need any modifications to stock boots. I’m running on a stock bore with all the free mods + full exhaust etc and it really woke things up.
I should really post some pictures but I’m pretty sure there is a thread with pics.
Old Oct 4, 2010 | 10:49 PM
work's Avatar
I found a thread on it. think this may be next in line. might put off the bb kit.
vfrpilot
Nov 13, 2010 01:13 PM
johnnyz62
Mar 15, 2007 06:47 AM
toomuchdust
Jan 22, 2007 02:59 PM
EMS_0525
Sep 9, 2006 05:53 PM
bryanklx250s
Jan 20, 2006 01:15 AM
