MCM check
Old Dec 19, 2019 | 07:44 PM
Rickybobby2's Avatar
Default MCM check
Does this look correct?
Exhuast camshaft
Intake camshaft
Old Dec 19, 2019 | 10:34 PM
durielk's Avatar
Can you come over and clean my bike?
Old Dec 19, 2019 | 10:51 PM
Klxster's Avatar
Yes - you've done it correctly - assuming the engine crank did not rotate at any time during the session, you should be good to go...
Good job on marking the cams (each with two yellow lines).. As your marks point out, the end result of the MCM is that both cams are rotated toward each other slightly (approximately 10 degrees)..
Test the engine carefully before touching the start button.. If it checks out, start it up to idle for the last check of possible problems..
Now, as I've said on the other thread, yank off the airbox lid, reprogram your EJK for lidless running and then add 1 to the midrange fueling... with this done, and if the chinabomb performs as well as a powerbomb, you now have a 25hp KLX that pulls hard from 3500 - 10,500 rpm !!!!!!!
Remember to hang on tight !
Old Dec 19, 2019 | 10:55 PM
Now, as I've said on the other thread, yank off the airbox lid, reprogram your EJK for lidless running and then add 1 to the midrange fueling... Remember to hang on tight !
Thanks man. I will take her out for a test drive tomorrow.
Old Dec 19, 2019 | 10:57 PM
I keep a thin coat of WD-40 on the engine so it stays clean longer and cleans up super easy. I have always don't that on all my bikes.
Old Dec 28, 2019 | 08:41 PM
Klxster's Avatar
Rickybobby2, how bout a sit rep on your modding efforts or results..?
Old Dec 29, 2019 | 08:36 PM
[QUOTE=Klxster;548183]Rickybobby2, how bout a sit rep on your modding efforts or results..?[/QUO
The bike is running great. I definitely can tell a difference as it accelerates to 60 mph very quickly. However I think I still need to dial in the fuel on the EJK. The bike still will not power wheelie in 1st, and wheelie power in second is about the same. It is as if it bogs down. I am going to try different fuel settings but would gladly try any suggested settings.
Old Dec 29, 2019 | 10:55 PM
Klxster's Avatar
Yes, your fueling is not correct.. I believe there are other recent postings from new EFI owners that talk about EJK settings.. But if all else fails, call EJK !
Klxster
Apr 3, 2023 02:42 AM
outrecording
Oct 3, 2018 11:03 PM
Sic Semper Tyrannis
Jun 24, 2017 02:17 PM
blz2dwl
Jun 18, 2017 03:28 PM
Richard Avatar
May 19, 2015 01:57 AM
