Making a Two Brothers Slip-on fit a FMF Powerbomb Header
Its too tight of a squeeze to fit, I tried sanding the tbr slip-on slightly but itll go in about a cm and just get stuck. Other than using a dremel is there a better way to make it fit loose enought that I can turn it during install and clamp it up? Pipe widener perhaps? Have a muffler shop do it?
They will be able to fit just fine with a little tweaking I just dont want to do any major damage. |
Solution I went to a local muffler shop and someone widened the pipe for me. Put some RTV silicone and clamped it now its perfect!!!
| All times are GMT. The time now is 10:50 AM. |
