-   -   Looking for front wheel hub (https://www.kawasakiforums.com/forum/klx-250s-71/looking-front-wheel-hub-49194/)
ekim250 Jun 26, 2023 07:26 PM
2009+ front wheel hub for a KLX250S or KLX250SF. Located in PNW.
Tacoma660 Jun 26, 2023 09:38 PM
eBay might be the best and cheapest route
klx678 Jun 27, 2023 01:43 PM
Wish you the best of luck. That darn electronic speedo setup is the headache. If it was only the pre-09 you'd have no problem. At least any of the 09 and later should work fine, but probably really hard to find.
ekim250 Jun 30, 2023 09:38 PM
Yes. Can't find one anywhere except stock from factory for $650 for just the hub. I have a 17" SF front that I want to convert to 19" but don't want to rip apart my original wheel.
klx678 Jul 1, 2023 12:12 PM
The one way to deal with this on the cheap would be to go with an earlier hub that fits, but without the speedo drive, then install a Vapor gauge setup in place of the OEM speedo. That would even allow use of some MX hubs with no drive what so ever. The speedo drive is the big stopper, whether the mechanical one or the electronic one.
