Looking to add some power
Old Nov 25, 2017 | 11:40 PM
addictedtogum's Avatar
Default Looking to add some power
Just picked up a 2006 KLX250s tonight and would like to add some simple power. After reading the forums it seems the way to go is a Dynojet Kit, KDX 220 Snorkel and an exhaust.
Is this the correct Dynojet?
Amazon Amazon
Is this the correct Snorkel?
https://www.ebay.com/itm/Kawasaki-14...dZ5M5k&vxp=mtr
Which exhaust should i go with? Looking for the best bang for the buck exhaust out there.
Can i do the modifications one at a time, or should they all be done at once?
thanks!
Old Nov 26, 2017 | 12:13 AM
Abramsgunner's Avatar
Best to do all at once. You can jet it with stock intake and exhaust to help with the factory lean condition, but you'll have to re-jet when you upgrade the exhaust and/or intake.
I run the Q4 and like it very much.
I have the '09, so I'm not sure which DJ kit works best on the '06... but there is a lifetime worth of jetting info here on the forum.
Old Nov 26, 2017 | 02:16 PM
Klxster's Avatar
If you are going to run with the lid on the airbox - snorkle or not - get the DJ 2152 kit and install as per instructions..
If you are interested in a max performance lidless setup, you can get the DJ2152 or DJ2206 , the appropriate extra jet(s), and install as per the lidless recipe..
Exhaust: Max performance requires a full system (header + slipon).
You can start learning of your options by reading the threads in my signature line, then look at all threads I've started..
Old Dec 5, 2017 | 10:31 PM
What are the gears on the bike currently? If its the stock 14-42, chuck those in the garbage and get a 13-45 setup.
Old Dec 6, 2017 | 03:55 AM
I have been told when I bought it that he geared the front sprocket down twice (a tooth each time) so I am guessing it is 12-42
Old Dec 6, 2017 | 09:51 AM
If you bought sprockets I'd recommend looking at ratios for the sprockets and use the biggest that will make the ratio you want. A 45/13 gives a ratio near the same as 48/14 provided a 48 can be fitted. A 47/14 can be had and fitted and gives a decent low gearing plus quick front sprocket changes to either a 13 or 15 if desired. Just start with a 47/15 when breaking the chain to length to have enough chain to do the change over. I was working that idea to have a 47/15 road gear and a 47/13 off road gear, but screwed up and made the chain two links short, by setting it up with the 47/13 first without thinking.
  • 42/14=3.00 Stock
  • 42/13=3.23
  • 45/13=3.46
  • 48/14=3.43
  • 47/14=3.36
  • (47/15=3.13)
  • (39/15=2.60 SM rear sprocket size and 15)
The bigger sprockets spread the load over more teeth and do not wrap the chain quite as tight wearing slower. Smaller the sprockets the more the chain has to move to wrap around them, wearing the pins a bit more. Granted it is minimal, but it is something. Plus if you run the bigger front sprocket, if you ever did need a drastic drop in gearing you always have a smaller one possible.
Old Dec 12, 2017 | 10:40 PM
LaGrasta's Avatar
Old Jan 21, 2019 | 08:58 PM
MMMMAMADDOG's Avatar
Hello All.
I'm after a header and silencer for my KLX250s 2007.
I see amazon and eBay want right around a grand for them. Can anyone out there help?
BeWell M
Old Jan 21, 2019 | 10:36 PM
Don't know how this helps, but, I picked up two used silencers and a header from ebay for about half price. I was patient and checked in often.
Old Jan 23, 2019 | 02:28 PM
Thanks
BeWell M/
ptbojeff
Jan 5, 2017 03:37 PM
Houstons4
Sep 20, 2016 08:45 PM
LemonRX
Sep 6, 2015 03:21 PM
Klxster
Oct 17, 2014 03:09 PM
brutus5000
Jun 9, 2011 04:20 PM
