Lightening the flywheel:)
Ok, the other day I was lightening a flywheel for a customer. Now...I've done about 12 of these over the past few years, and when I set them up on my lathe I always indicated the center bore to make sure it's at zero run out. Here's what i have found on a couple of KLX flywheels(including my own) they are NOT concentric. Meaning the center bore and the outside diameter are a bit out of wack....about .007 to .009 thousandsths of an inch. Now this would explain why my KLX had a slight vibration at 5k rpm. So, not only did the 1lb. of material that I took off the flywheel help the motor rev up quicker but the annoying vibration is now gone as well.:)
1lbof weight - that's a good bit! How does it feel after that?
I like the tractor-like feel - but at times I wonder what it'd be like with a much lighter flywheel. |
Is that bad manufacturing...or what?
How much weight would be removed just to true it up and take out the vibration? Interesting... |
How much does it weigh overall to begin with?
Lighter flywheel sounds like something I'd be interested in. |
Pics please. How much do you charge to do it?
Originally Posted by cegusman
(Post 456904)
Originally Posted by IDRIDR
(Post 456893)
(Post 456887)
Hmmm.. I may have to try this. I'm going to try to source an extra flywheel so I can have both.. I'll be in touch :)
EDIT - what am I talking about? I forgot I have an extra entire bottom end... I am going to pull that flywheel. I will shoot you a message when I have it off to see where to send it. Thanks! |
Cool.
