LETS GO TOP SPEED KLX
Old Apr 21, 2008 | 07:28 PM
stellar_d's Avatar
Default RE: LETS GO TOP SPEED KLX
13/45 gone 80miles. This was very calm weather, WOT and flat flat flat road
EMS what you mean indicated, is the speedo quite a bit out?
Old Apr 21, 2008 | 09:26 PM
LearjetMinako's Avatar
78mph on the speedo (74mph on GPS) in stock form with no help from the wind, hills, or drafting. If I draft a vehicle, I know it can hit 85mph good enough.
As for that pavement sandwhich, no thanks. But the steering does get freaky after 70mph.
StockKLXspeedometers are usually 10% faster. Before, when I did 50mph, GPS was 45mph. After the needle twick, if the speedo says 50mph, GPS is 49.5mph. But the faster you go, the higher the speedo reads than actually. Below 30mph, the speedo is slower, (speedo = 30, GPS =32). Between 30-50mph, its acurrate enough.
Old Apr 21, 2008 | 10:42 PM
shaydara's Avatar
I'm flat out getting over 105kmh which is about 65mph in stock form. When I hit 7000rpm the bike really screams so I usualy just hang around 6000rpm. I can't wait to put an after market pipe on my klx, its been along time coming.
Cheers!
Old Apr 22, 2008 | 03:09 AM
Sid Post's Avatar
ORIGINAL: Flood_33
80 is as high as i will get it... no steering damper in the north texas wind = speed wobbles.... enjoy your pavement sandwhich..
You can say that again. Above 65MPH the steering is very quick. Gusty side winds or semi-trucks are hard to handle. Hit 85MPH indicated once and don't plan on doing that ever again.
My speedometer has read a consistent 5MPH fast when I hit a traffic radar (tried it from 20MPH to 50MPH over and over one day ). Don't know how accurate it is faster then that since I was in a 25MPH zone at the time. [sm=lildevil.gif]
Old Apr 22, 2008 | 06:04 AM
drewski's Avatar
I hit 80mph for about 10 seconds. 60 is just right.
Old May 12, 2008 | 11:01 PM
slimenlyman's Avatar
It does the speed limit and than some. gearing it down giving the torque I need. If speed is what you what you should go to a sportbike my 05 636 would fly 120kpm ion first. So I said I went to comfortand having to work the bike to th maximum install of waitiing flip backward n sure power aone
Old May 13, 2008 | 06:40 AM
Leem's Avatar
140km/hour
Had more in her but it got too scary
13th front standard rear
The klx will get better top speed with 13tooth as the engine seems to run in a sweeter rev range.
The bike also seems to be quicker with the rear number plate fender removed as it must create wind drag
Old May 13, 2008 | 08:44 AM
WestOzKLX's Avatar
Thread jack!
Hey Leem, how's the new tank going for ya?
Gonna post the photos and a mod report?
Old May 13, 2008 | 11:41 AM
big lou's Avatar
sport bikes are played they arelate 90s duel sports are in.dirt street what ever.
Old May 13, 2008 | 12:49 PM
david681's Avatar
85-90mph with stock front sproket and 80mph with 13T front.
